주요 콘텐츠로 건너뛰기
ASUS Q400A-BHI7N03 Screen Replacement
필요한 것
  1. ASUS Q400A-BHI7N03 Screen Replacement, Screen: 1 단계, 이미지 1/1
    • Flip the laptop on its back side with the battery facing toward you.
    • Slide the tabs with lock/unlock symbol, to the unlock position.
    • Grabbing the top edge of the battery, lift upward to relieve the battery from its slot.
  2. ASUS Q400A-BHI7N03 Screen Replacement: 2 단계, 이미지 1/1
    • Lift the two black plastic circles off the screen using the plastic spudger.
    • Unscrew the two 8mm Phillips #0 screws.
  3. ASUS Q400A-BHI7N03 Screen Replacement: 3 단계, 이미지 1/1
    • Pry the front edges of the screen using the spudger.
  4. ASUS Q400A-BHI7N03 Screen Replacement: 4 단계, 이미지 1/1
    • Remove the four black 8mm Phillips #0 screws and set them aside.
  5. ASUS Q400A-BHI7N03 Screen Replacement: 5 단계, 이미지 1/1
    • Pry the LCD from the front frame.
  6. ASUS Q400A-BHI7N03 Screen Replacement: 6 단계, 이미지 1/1
    • Pull the gold ribbon cable to disconnect the screen from the laptop.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Wan Ahmad Aiman
회원 가입일: 10/31/18
403 평판
안내서 2개 작성하였습니다
IUPUI, Team S1-G3, Harley Fall 2018 IUPUI, Team S1-G3, Harley Fall 2018 회원
IUPUI-HARLEY-F18S1G3
3 회원들
안내서 2개 작성하였습니다
댓글 한 개
Can you tell me what is the part number and description for the display, I need to order one to replace mi ASUS broken screen. Thanks in advance...!!!
Daniel Ventura Avalos - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 550
