소개
If the screen is damaged, or has an incorrect display, it should replaced. The following is a comprehensive guide for replacing the screen.
필요한 것
Flip the laptop on its back side with the battery facing toward you.
Slide the tabs with lock/unlock symbol, to the unlock position.
Grabbing the top edge of the battery, lift upward to relieve the battery from its slot.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 한 개
Can you tell me what is the part number and description for the display, I need to order one to replace mi ASUS broken screen. Thanks in advance...!!!
