소개
The hard drive, responsible for storing all your important files. Without a hard drive, your computer would have nothing to operate off of. It would be a machine without code. Therefore, issues with it tend to be very serious. Things such as corruption can cause important files to be lost or damaged. That’s why this guide will be very helpful, in the event that you need to replace the hard drive of your ASUS Q405U.
필요한 것
Using the Phillips #1 screwdriver, remove eleven (11) 1.5 mm screws from the back cover.
다른 한 분이 해당 안내서를 완성하였습니다.
