주요 콘텐츠로 건너뛰기
ASUS Q524U Hard Drive Replacement
필요한 것
  1. ASUS Q524U Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Turn the laptop on its back, and place it on a flat and smooth surface. Identify the location of the back panels screws.
  2. ASUS Q524U Hard Drive Replacement: 2 단계, 이미지 1/3 ASUS Q524U Hard Drive Replacement: 2 단계, 이미지 2/3 ASUS Q524U Hard Drive Replacement: 2 단계, 이미지 3/3
    • Remove all ten 1.3mm screws on the outer edge of the back panel using the T4 screwdriver.
  3. ASUS Q524U Hard Drive Replacement: 3 단계, 이미지 1/1
    • Using the opening tool or spudger, remove the back panel by working your way around the perimeter and pry it open gently.
  4. ASUS Q524U Hard Drive Replacement: 4 단계, 이미지 1/1
    • Remove the back panel, exposing the motherboard.
    • Set the panel aside, skin up to avoid scratches.
  5. ASUS Q524U Hard Drive Replacement: 5 단계, 이미지 1/1
    • Using the T4 screwdriver, remove the four 1.3 mm screws connecting the hard drive to the motherboard.
    • The hard-drive is located in the bottom left corner of the motherboard.
  6. ASUS Q524U Hard Drive Replacement: 6 단계, 이미지 1/2 ASUS Q524U Hard Drive Replacement: 6 단계, 이미지 2/2
    • Once all the screws are removed from the port, lift the hard drive out of its casing. After, disconnect the hard drive from the motherboard.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Colton Kirby
회원 가입일: 09/15/20
181 평판
안내서 1개 작성함
University of Memphis, Team S3-G15, Willis Fall 2020 University of Memphis, Team S3-G15, Willis Fall 2020 회원
UM-WILLIS-F20S3G15
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 41
전체 시간: 3,246
