주요 콘텐츠로 건너뛰기
ASUS R554L Battery Replacement
필요한 것
  1. ASUS R554L Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop so the bottom is facing upward.
    • Remove ten screws using a Phillips #0 screwdriver.
  2. ASUS R554L Battery Replacement: 2 단계, 이미지 1/3 ASUS R554L Battery Replacement: 2 단계, 이미지 2/3 ASUS R554L Battery Replacement: 2 단계, 이미지 3/3
    • Using your fingertips, carefully pull the backplate in an upright direction.
    • Continue along the edges until the backplate is fully removed.
    • It's normal to hear cracking while pulling up on the plate.
  3. ASUS R554L Battery Replacement: 3 단계, 이미지 1/3 ASUS R554L Battery Replacement: 3 단계, 이미지 2/3 ASUS R554L Battery Replacement: 3 단계, 이미지 3/3
    • Remove the four screws from the battery using a Phillips #0 screwdriver.
    • Pull up on the cable connected to the motherboard to remove.
    • Remove the battery from the bay.
  4. ASUS R554L Battery Replacement: 4 단계, 이미지 1/3 ASUS R554L Battery Replacement: 4 단계, 이미지 2/3 ASUS R554L Battery Replacement: 4 단계, 이미지 3/3
    • Place the new battery in the bay.
    • Install the battery cable to the motherboard, applying pressure in a downward direction.
    • Screws the screws back in using a Phillips #0 screwdriver.
  5. ASUS R554L Battery Replacement: 5 단계, 이미지 1/3 ASUS R554L Battery Replacement: 5 단계, 이미지 2/3 ASUS R554L Battery Replacement: 5 단계, 이미지 3/3
    • Align the backplate.
    • Starting with the upper right corner, apply pressure in a downward angle.
    • Repeat the process around the backplate until it's fully secure.
  6. ASUS R554L Battery Replacement: 6 단계, 이미지 1/2 ASUS R554L Battery Replacement: 6 단계, 이미지 2/2
    • Screw the backplate screws back in using a Phillips #0 screwdriver.
결론
Once the new battery is installed, leave the charger connected to the laptop over night to ensure the battery is holding a charge
다른 한 분이 해당 안내서를 완성하였습니다.
Joshua Chavez
회원 가입일: 01/31/22
160 평판
안내서 1개 작성함
CSU Los Angeles, Team 4-49, Briggs Spring 2022 CSU Los Angeles, Team 4-49, Briggs Spring 2022 회원
CSULA-BRIGGS-S22S4G49
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 34
30일 전: 255
전체 시간: 4,559
