주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
ASUS ROG G46VW Keyboard Replacement
필요한 것
  1. ASUS ROG G46VW Keyboard Replacement, Speaker Cover: 1 단계, 이미지 1/1
    • Gently pry the back hinge cover piece away from the device.
  2. ASUS ROG G46VW Keyboard Replacement: 2 단계, 이미지 1/1
    • Disconnect the speaker cable from the motherboard.
  3. ASUS ROG G46VW Keyboard Replacement, RAM: 3 단계, 이미지 1/2 ASUS ROG G46VW Keyboard Replacement, RAM: 3 단계, 이미지 2/2
    • Lift the screw cover and remove the screw using a Phillips #0 screwdriver.
  4. ASUS ROG G46VW Keyboard Replacement: 4 단계, 이미지 1/1
    • Remove the RAM cover by lifting the screw cover and pulling away firmly.
  5. ASUS ROG G46VW Keyboard Replacement: 5 단계, 이미지 1/2 ASUS ROG G46VW Keyboard Replacement: 5 단계, 이미지 2/2
    • Push outwards on the clips to release the RAM stick. The stick should pop up at an angle.
  6. ASUS ROG G46VW Keyboard Replacement: 6 단계, 이미지 1/1
    • Pull out the RAM stick carefully.
    • Do not use a prying motion as this will damage the hardware. Be careful not to damage the gold section of the RAM stick.
  7. ASUS ROG G46VW Keyboard Replacement: 7 단계, 이미지 1/1
    • Repeat steps 3-4 to remove the second RAM stick.
  8. ASUS ROG G46VW Keyboard Replacement, Keyboard: 8 단계, 이미지 1/1
    • Remove the two screws from underneath the RAM cover.
  9. ASUS ROG G46VW Keyboard Replacement: 9 단계, 이미지 1/1
    • Remove all of the screws from the bottom of the case.
    • If replacing the screen, remove the rubber feet to reveal two more screws.
  10. ASUS ROG G46VW Keyboard Replacement: 10 단계, 이미지 1/1
    • Turn the laptop over and remove the screws as shown
  11. ASUS ROG G46VW Keyboard Replacement: 11 단계, 이미지 1/1
    • Carefully pry the keyboard away using your spudger and the opening tools.
    • Be sure not to damage the clips holding the keyboard to the bottom case.
  12. ASUS ROG G46VW Keyboard Replacement: 12 단계, 이미지 1/2 ASUS ROG G46VW Keyboard Replacement: 12 단계, 이미지 2/2
    • Detach the ribbon cable by releasing the clip
결론
Amon Stewart
회원 가입일: 09/21/18
466 평판
안내서 4개 작성하였습니다
University of North Texas, Team S6-G3, Thompson Fall 2018 University of North Texas, Team S6-G3, Thompson Fall 2018 회원
UNT-THOMPSON-F18S6G3
4 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 832
