주요 콘텐츠로 건너뛰기
ASUS ROG G46VW Motherboard Replacement
필요한 것
  1. ASUS ROG G46VW Motherboard Replacement, RAM: 1 단계, 이미지 1/2 ASUS ROG G46VW Motherboard Replacement, RAM: 1 단계, 이미지 2/2
    • Lift the screw cover and remove the screw using a Phillips #0 screwdriver.
  2. ASUS ROG G46VW Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the RAM cover by lifting the screw cover and pulling away firmly.
  3. ASUS ROG G46VW Motherboard Replacement: 3 단계, 이미지 1/2 ASUS ROG G46VW Motherboard Replacement: 3 단계, 이미지 2/2
    • Push outwards on the clips to release the RAM stick. The stick should pop up at an angle.
  4. ASUS ROG G46VW Motherboard Replacement: 4 단계, 이미지 1/1
    • Pull out the RAM stick carefully.
    • Do not use a prying motion as this will damage the hardware. Be careful not to damage the gold section of the RAM stick.
  5. ASUS ROG G46VW Motherboard Replacement: 5 단계, 이미지 1/1
    • Repeat steps 3-4 to remove the second RAM stick.
  6. ASUS ROG G46VW Motherboard Replacement, Speaker Cover: 6 단계, 이미지 1/1
    • Gently pry the back hinge cover piece away from the device.
  7. ASUS ROG G46VW Motherboard Replacement: 7 단계, 이미지 1/1
    • Disconnect the speaker cable from the motherboard.
  8. ASUS ROG G46VW Motherboard Replacement, Keyboard: 8 단계, 이미지 1/1
    • Remove the two screws from underneath the RAM cover.
  9. ASUS ROG G46VW Motherboard Replacement: 9 단계, 이미지 1/1
    • Remove all of the screws from the bottom of the case.
    • If replacing the screen, remove the rubber feet to reveal two more screws.
  10. ASUS ROG G46VW Motherboard Replacement: 10 단계, 이미지 1/1
    • Turn the laptop over and remove the screws as shown
  11. ASUS ROG G46VW Motherboard Replacement: 11 단계, 이미지 1/1
    • Carefully pry the keyboard away using your spudger and the opening tools.
    • Be sure not to damage the clips holding the keyboard to the bottom case.
  12. ASUS ROG G46VW Motherboard Replacement: 12 단계, 이미지 1/2 ASUS ROG G46VW Motherboard Replacement: 12 단계, 이미지 2/2
    • Detach the ribbon cable by releasing the clip
  13. ASUS ROG G46VW Motherboard Replacement, Screen: 13 단계, 이미지 1/2 ASUS ROG G46VW Motherboard Replacement, Screen: 13 단계, 이미지 2/2
    • Remove screws from silver braces.
  14. ASUS ROG G46VW Motherboard Replacement: 14 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use tweezers to remove golden screw caps.
  15. ASUS ROG G46VW Motherboard Replacement: 15 단계, 이미지 1/1
    • Remove tape and gently pull up on golden cap connectors to disconnect them.
  16. ASUS ROG G46VW Motherboard Replacement: 16 단계, 이미지 1/1
    • Gently pull the white connector until it comes loose.
  17. ASUS ROG G46VW Motherboard Replacement, Indicator Lights: 17 단계, 이미지 1/1
    • With the motherboard exposed, locate the Indicator Lights and their white plastic housing piece.
  18. ASUS ROG G46VW Motherboard Replacement: 18 단계, 이미지 1/1
    • Remove all 3 screws from the motherboard connection using the Phillips #0 screwdriver.
    • Pull the plastic white housing piece away from the case.
  19. ASUS ROG G46VW Motherboard Replacement: 19 단계, 이미지 1/1
    • Locate the flat LED cable that connects the lights to the motherboard.
    • Flip the black cover upwards before pulling on the cable.
    • Repeat for the other connector piece.
  20. ASUS ROG G46VW Motherboard Replacement, Motherboard: 20 단계, 이미지 1/1
    • Locate and remove the screws.
    • Removing the screws allows you to lift up the motherboard
  21. ASUS ROG G46VW Motherboard Replacement: 21 단계, 이미지 1/1
    • After lifting the motherboard up you can replace any component on it, such as the fans.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ruben Olivares
회원 가입일: 09/24/18
153 평판
안내서 1개 작성함
University of North Texas, Team S6-G3, Thompson Fall 2018 University of North Texas, Team S6-G3, Thompson Fall 2018 회원
UNT-THOMPSON-F18S6G3
4 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 19
전체 시간: 2,026
