주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS ROG G46VW Screen Replacement
필요한 것
  1. ASUS ROG G46VW Screen Replacement, Speaker Cover: 1 단계, 이미지 1개 중 1개
    • Gently pry the back hinge cover piece away from the device.
  2. ASUS ROG G46VW Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Disconnect the speaker cable from the motherboard.
  3. ASUS ROG G46VW Screen Replacement, RAM: 3 단계, 이미지 2개 중 1개 ASUS ROG G46VW Screen Replacement, RAM: 3 단계, 이미지 2개 중 2개
    • Lift the screw cover and remove the screw using a Phillips #0 screwdriver.
  4. ASUS ROG G46VW Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the RAM cover by lifting the screw cover and pulling away firmly.
  5. ASUS ROG G46VW Screen Replacement: 5 단계, 이미지 2개 중 1개 ASUS ROG G46VW Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Push outwards on the clips to release the RAM stick. The stick should pop up at an angle.
  6. ASUS ROG G46VW Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Pull out the RAM stick carefully.
    • Do not use a prying motion as this will damage the hardware. Be careful not to damage the gold section of the RAM stick.
  7. ASUS ROG G46VW Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Repeat steps 3-4 to remove the second RAM stick.
  8. ASUS ROG G46VW Screen Replacement, Keyboard: 8 단계, 이미지 1개 중 1개
    • Remove the two screws from underneath the RAM cover.
  9. ASUS ROG G46VW Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Remove all of the screws from the bottom of the case.
    • If replacing the screen, remove the rubber feet to reveal two more screws.
  10. ASUS ROG G46VW Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Turn the laptop over and remove the screws as shown
  11. ASUS ROG G46VW Screen Replacement: 11 단계, 이미지 1개 중 1개
    • Carefully pry the keyboard away using your spudger and the opening tools.
    • Be sure not to damage the clips holding the keyboard to the bottom case.
  12. ASUS ROG G46VW Screen Replacement: 12 단계, 이미지 2개 중 1개 ASUS ROG G46VW Screen Replacement: 12 단계, 이미지 2개 중 2개
    • Detach the ribbon cable by releasing the clip
  13. ASUS ROG G46VW Screen Replacement, Screen: 13 단계, 이미지 2개 중 1개 ASUS ROG G46VW Screen Replacement, Screen: 13 단계, 이미지 2개 중 2개
    • Remove screws from silver braces.
  14. ASUS ROG G46VW Screen Replacement: 14 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to remove golden screw caps.
  15. ASUS ROG G46VW Screen Replacement: 15 단계, 이미지 1개 중 1개
    • Remove tape and gently pull up on golden cap connectors to disconnect them.
  16. ASUS ROG G46VW Screen Replacement: 16 단계, 이미지 1개 중 1개
    • Gently pull the white connector until it comes loose.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Ryan Riley
회원 가입일: 09/21/18
154 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 23
전체 시간: 678
