소개
If your gaming laptop has begun to overheat or the fans are no longer working, this guide will provide a solution and replace the broken fans.
필요한 것
Remove the 6 screws on the edge of the laptop using a screwdriver.
Remove the back casing being held on by the one single screw. First, lift the casing at the edge where the screw once was, then carefully lift at the rest of the edges to loosen the casing. Pull the casing towards the edge where the screw was.
Remove the battery by sliding the switch circled in the picture and pulling the battery out.
Flip the laptop over and pop the back cover off behind the screen, by grabbing it on either side and pulling it up, vertically off of the laptop.
There is a cable connecting the cover to the laptop, shown in picture 2.
Disconnect the cable by pulling apart the white connectors, shown in picture 3.
You may now remove the keyboard plate. Simply lift from the back, and pull it off all the way around.
Caution with removing the keyboard, as there are 5 ribbon cables that connect the motherboard to the keyboard (motherboard port locations shown in picture 2).
The ribbon cables must be carefully disconnected from the motherboard side, by flipping a latch on the port and pulling the ribbon out.
다른 5명이 해당 안내서를 완성하였습니다.
