주요 콘텐츠로 건너뛰기
ASUS ROG G75VX-BHI7N11 Wireless Communication Chip Replacement
필요한 것
  1. ASUS ROG G75VX-BHI7N11 Wireless Communication Chip Replacement, ASUS ROG G75VX-BHI7N11 Disassembly: 1 단계, 이미지 1/1
    • Remove the 6 screws on the edge of the laptop using a screwdriver.
    • Remove the back casing being held on by the one single screw. First, lift the casing at the edge where the screw once was, then carefully lift at the rest of the edges to loosen the casing. Pull the casing towards the edge where the screw was.
    • Remove the battery by sliding the switch circled in the picture and pulling the battery out.
  2. ASUS ROG G75VX-BHI7N11 Wireless Communication Chip Replacement: 2 단계, 이미지 1/1
    • Remove the 11 screws circled in the picture using a Phillips head screwdriver. They should be labeled on the laptop with a capital A, shown circled in red.
    • Remove the screw labeled C.
  3. ASUS ROG G75VX-BHI7N11 Wireless Communication Chip Replacement: 3 단계, 이미지 1/1
    • Remove the 5 screws circled in the picture, located where the battery pack once was.
  4. ASUS ROG G75VX-BHI7N11 Wireless Communication Chip Replacement: 4 단계, 이미지 1/1
    • Remove the DVD ROM on the side of the computer, by pulling it out. If necessary, use a plastic opening tool.
  5. ASUS ROG G75VX-BHI7N11 Wireless Communication Chip Replacement: 5 단계, 이미지 1/1
    • Remove the three screws located where the DVD ROM once was, on the screen side of the laptop.
  6. ASUS ROG G75VX-BHI7N11 Wireless Communication Chip Replacement: 6 단계, 이미지 1/3 ASUS ROG G75VX-BHI7N11 Wireless Communication Chip Replacement: 6 단계, 이미지 2/3 ASUS ROG G75VX-BHI7N11 Wireless Communication Chip Replacement: 6 단계, 이미지 3/3
    • Flip the laptop over and pop the back cover off behind the screen, by grabbing it on either side and pulling it up, vertically off of the laptop.
    • There is a cable connecting the cover to the laptop, shown in picture 2.
    • Disconnect the cable by pulling apart the white connectors, shown in picture 3.
  7. ASUS ROG G75VX-BHI7N11 Wireless Communication Chip Replacement: 7 단계, 이미지 1/2 ASUS ROG G75VX-BHI7N11 Wireless Communication Chip Replacement: 7 단계, 이미지 2/2
    • There will be two smaller and two larger black screws on each hinge holding the laptop screen onto the computer. Remove all four of the larger screws with your P0 screwdriver.
    • There is one screw on either side of the keyboards, next to the screen hinges. Remove both screws.
  8. ASUS ROG G75VX-BHI7N11 Wireless Communication Chip Replacement: 8 단계, 이미지 1/2 ASUS ROG G75VX-BHI7N11 Wireless Communication Chip Replacement: 8 단계, 이미지 2/2
    • You may now remove the keyboard plate. Simply lift from the back, and pull it off all the way around.
    • Caution with removing the keyboard, as there are 5 ribbon cables that connect the motherboard to the keyboard (motherboard port locations shown in picture 2).
    • The ribbon cables must be carefully disconnected from the motherboard side, by flipping a latch on the port and pulling the ribbon out.
  9. ASUS ROG G75VX-BHI7N11 Wireless Communication Chip Replacement, Wireless Communication Chip: 9 단계, 이미지 1/2 ASUS ROG G75VX-BHI7N11 Wireless Communication Chip Replacement, Wireless Communication Chip: 9 단계, 이미지 2/2
    • If you look between the fan (upper right in the first picture), and the hard drive bay (lower right), there is a small white square. (Enlarged in second picture) This is the WiFi chip.
  10. ASUS ROG G75VX-BHI7N11 Wireless Communication Chip Replacement: 10 단계, 이미지 1/2 ASUS ROG G75VX-BHI7N11 Wireless Communication Chip Replacement: 10 단계, 이미지 2/2
    • If you look at picture one, circled are the micro-coaxial cables that connect the WiFi chip to the screen. These simply pull off.
    • Picture 2 has circled the screws that connect the WiFi chip to the motherboard. Remove these with your P0 screwdriver, and the chip will slide out away from its white port.
    • The WiFi chip is now disconnected, and ready to be replaced with your new one.
결론
To reassemble your device, follow these instructions in reverse order. Make sure that you reconnect the micro-coaxial cables to the correct terminals. The terminals are labeled with small colored triangles.
다른 3명이 해당 안내서를 완성하였습니다.
Cristian Rangel
회원 가입일: 01/25/17
444 평판
안내서 2개 작성하였습니다
Cal Poly, Team 8-3, Banghart Winter 2017 Cal Poly, Team 8-3, Banghart Winter 2017 회원
CPSU-BANGHART-W17S8G3
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 908
