주요 콘텐츠로 건너뛰기
ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement
필요한 것
  1. ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement, Internal Hard Drive: 1 단계, 이미지 1/1
    • Remove the six screws on the back of the laptop using a Phillips screwdriver.
    • Remove the back casing being held on by the one single screw. First lift the casing at the edge where the screw once was, then carefully lift at the rest of the edges to loosen the casing. Pull the casing towards the edge where the screw was.
  2. ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement: 2 단계, 이미지 1/2 ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement: 2 단계, 이미지 2/2
    • Locate the metal hard drive bay in the bottom left corner of the laptop.
    • Remove the two black screws securing the metal hard drive to the plastic.
    • Pull the tab to the right and slide to unseat the hard drive bay, then lift out.
  3. ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement: 3 단계, 이미지 1/2 ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement: 3 단계, 이미지 2/2
    • Remove the two screws on the sides of the hard drive panel, shown circled. Repeat for the other side.
    • Replace the hard drive.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Logan Smith
회원 가입일: 01/25/17
783 평판
안내서 4개 작성하였습니다
Cal Poly, Team 8-3, Banghart Winter 2017 Cal Poly, Team 8-3, Banghart Winter 2017 회원
CPSU-BANGHART-W17S8G3
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 1,000
