이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Start with flipping the laptop over so that the bottom side is facing up.
Remove the screw for the small panel with a Phillips #1 screwdriver.
Use your plastic opening tool to lift up the cover to remove it.
Remove the screw beneath the service cover with a Phillips #1 screwdriver.
Remove the 9 screws around the perimeter of the back case with a Phillips #1 screwdriver.
Use a plastic opening tool to pry the back cover off of the device.
Remove the back cover exposing the battery.
Remove the single screw securing the battery with a Phillips #1 screwdriver.
Gently pull the battery cable from its connector on the motherboard.
Lift up on the battery to remove it.
다른 2명이 해당 안내서를 완성하였습니다.
