주요 콘텐츠로 건너뛰기
ASUS ROG Strix GL503VD-DB71 Fan Replacement
필요한 것
  1. ASUS ROG Strix GL503VD-DB71 Fan Replacement, Fan: 1 단계, 이미지 1/3 ASUS ROG Strix GL503VD-DB71 Fan Replacement, Fan: 1 단계, 이미지 2/3 ASUS ROG Strix GL503VD-DB71 Fan Replacement, Fan: 1 단계, 이미지 3/3
    • Flip the laptop over so that the bottom is facing up.
    • Remove the ten screws around the edges and in the center of the back case with a Phillips #1 screwdriver.
  2. ASUS ROG Strix GL503VD-DB71 Fan Replacement: 2 단계, 이미지 1/3 ASUS ROG Strix GL503VD-DB71 Fan Replacement: 2 단계, 이미지 2/3 ASUS ROG Strix GL503VD-DB71 Fan Replacement: 2 단계, 이미지 3/3
    • Pry up the triangular service cover with a plastic opening tool.
    • Remove the single Phillips #1 screw beneath the cover.
    • Pry up the remainder of the back cover with a plastic opening tool and remove the back cover.
  3. ASUS ROG Strix GL503VD-DB71 Fan Replacement: 3 단계, 이미지 1/3 ASUS ROG Strix GL503VD-DB71 Fan Replacement: 3 단계, 이미지 2/3 ASUS ROG Strix GL503VD-DB71 Fan Replacement: 3 단계, 이미지 3/3
    • Remove the four screws from the fans with a Phillips #1 screwdriver.
    • Unplug each of the fan connectors from the motherboard.
    • Remove each fan by lifting it from the case.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Bryce Davis
회원 가입일: 01/30/20
494 평판
안내서 4개 작성하였습니다
댓글 2개
Hi! I have a GL503VD-EB72 and my fans look ever so slightly different. Trying to replace one right now but I’m seeing a lot of variety in what’s available on eBay and amazon…How can I tell if my fans are 5V or 12V?
Kirsten M - 답글
WTF i can find a 12 V for my GL503V
mrparisalexandre - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 31
전체 시간: 4,648
