소개
Cleaning the fans on your ASUS ROG Zephyrus M15 GU205L is an essential maintenance task to ensure optimal performance and prevent overheating. Dust and debris can accumulate over time, hindering the airflow and causing the fans to work harder. Here's a step-by-step guide to help you clean the fans:
필요한 것
Remove fifteen 10 mm screws from the bottom cover using a Phillips #0 screwdriver.
Use the microfiber cloth to wipe any surface dust off the fan fins.
거의 끝나갑니다!
결론
