주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS TUF Dash F15 Lower Case Replacement
필요한 것
  1. ASUS TUF Dash F15 Lower Case Replacement, Unfasten the lower case: 1 단계, 이미지 3개 중 1개 ASUS TUF Dash F15 Lower Case Replacement, Unfasten the lower case: 1 단계, 이미지 3개 중 2개 ASUS TUF Dash F15 Lower Case Replacement, Unfasten the lower case: 1 단계, 이미지 3개 중 3개
    • Remove the 14 Phillips screws securing the lower case:
    • Seven 8.8 mm screws
    • Seven 10.1 mm screws
    • Use a Phillips screwdriver to loosen the captive screw.
    • Loosening this captive screw will pop up and separate the bottom-right corner of the back cover from the chassis.
    • During reassembly, tighten the captive screw before the rest of the screws.
  2. ASUS TUF Dash F15 Lower Case Replacement, Insert an opening pick: 2 단계, 이미지 2개 중 1개 ASUS TUF Dash F15 Lower Case Replacement, Insert an opening pick: 2 단계, 이미지 2개 중 2개
    • Insert an opening pick between the lower case and the chassis on the front right edge near the captive screw.
  3. ASUS TUF Dash F15 Lower Case Replacement, Release the clips: 3 단계, 이미지 3개 중 1개 ASUS TUF Dash F15 Lower Case Replacement, Release the clips: 3 단계, 이미지 3개 중 2개 ASUS TUF Dash F15 Lower Case Replacement, Release the clips: 3 단계, 이미지 3개 중 3개
    • Slide the pick along the front edge to release the clips securing the lower case.
    • Repeat this process along the perimeter of the lower case to release the remaining clips.
  4. ASUS TUF Dash F15 Lower Case Replacement, Remove the lower case: 4 단계, 이미지 3개 중 1개 ASUS TUF Dash F15 Lower Case Replacement, Remove the lower case: 4 단계, 이미지 3개 중 2개 ASUS TUF Dash F15 Lower Case Replacement, Remove the lower case: 4 단계, 이미지 3개 중 3개
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
결론
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our ASUS TUF answers community for help.
다른 4명이 해당 안내서를 완성하였습니다.
Spencer Day
회원 가입일: 09/14/22
159,805 평판
안내서 1,045개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,977개를 작성함
4가이드 댓글
do you know how wide the screws are cuz i lost 2 of them and i have trouble buying them and i only found universal scews that are good for lenght but i dont know wide
Natan Jot - 답글
I also lost some screws :S
Eric Sanchez -
I'm missing two of the bigger screws too. I don't think its a coincidence but a mistake 'cause I have opened my laptop twice and the two screws were missing on the first time I opened it.
Joel Poikolainen -
Hi there, I hope you're doing well. I was just wondering if there is any possibility to buy a motherboard of a newer model of this laptop(one that has the same body) and replace it with mine. Because I have the 3050 ti i5 but I would like to upgrade it to i7 3070 version (it seems to have the same shape and size). Do you think this is possible?
Adam - 답글
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 56
지난 30일: 276
전체 시간: 7,376
