주요 콘텐츠로 건너뛰기
ASUS TUF Gaming F15 FX506L Back Cover Replacement
필요한 것
  1. ASUS TUF Gaming F15 FX506L Back Cover Replacement, Unfasten the back cover: 1 단계, 이미지 1/2 ASUS TUF Gaming F15 FX506L Back Cover Replacement, Unfasten the back cover: 1 단계, 이미지 2/2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Phillips screwdriver to remove the 10 screws securing the back cover:
    • Seven 11.6 mm screws
    • Two 14.6 mm screws
    • One 6 mm screw
    • Use a Phillips screwdriver to loosen the captive screw.
    • Loosening this captive screw will pop up and separate the bottom-right corner of the back cover from the chassis.
    • During reassembly, tighten the captive screw before the rest of the screws.
  2. ASUS TUF Gaming F15 FX506L Back Cover Replacement, Release the clips: 2 단계, 이미지 1/2 ASUS TUF Gaming F15 FX506L Back Cover Replacement, Release the clips: 2 단계, 이미지 2/2
    • Insert an opening pick between the bottom-right corner of the back cover and the chassis, near the captive screw.
    • Pry up to release the clips securing the back cover.
    • You'll hear a click whenever a clip is released.
  3. ASUS TUF Gaming F15 FX506L Back Cover Replacement, Release the remaining clips: 3 단계, 이미지 1/3 ASUS TUF Gaming F15 FX506L Back Cover Replacement, Release the remaining clips: 3 단계, 이미지 2/3 ASUS TUF Gaming F15 FX506L Back Cover Replacement, Release the remaining clips: 3 단계, 이미지 3/3
    • Insert your opening pick again between the top-left corner of the back cover and the chassis.
    • Insert the pick at a steep angle. Pry up to release the remaining clips securing the back cover.
  4. ASUS TUF Gaming F15 FX506L Back Cover Replacement, Remove the back cover: 4 단계, 이미지 1/3 ASUS TUF Gaming F15 FX506L Back Cover Replacement, Remove the back cover: 4 단계, 이미지 2/3 ASUS TUF Gaming F15 FX506L Back Cover Replacement, Remove the back cover: 4 단계, 이미지 3/3
    • Lift the back cover off the chassis and remove it.
    • If your back cover is stuck to the chassis, use an opening pick to release the clips around the back cover's perimeter.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our ASUS TUF laptop answers community for help.
다른 3명이 해당 안내서를 완성하였습니다.
Clay Eickemeyer
회원 가입일: 09/19/22
67,303 평판
안내서 453개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,430개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 68
30일 전: 318
전체 시간: 6,738
