주요 콘텐츠로 건너뛰기
ASUS TUF Gaming F15 FX506L Left SSD Replacement
필요한 것
  1. ASUS TUF Gaming F15 FX506L Left SSD Replacement, Unfasten the back cover: 1 단계, 이미지 1/2 ASUS TUF Gaming F15 FX506L Left SSD Replacement, Unfasten the back cover: 1 단계, 이미지 2/2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Phillips screwdriver to remove the 10 screws securing the back cover:
    • Seven 11.6 mm screws
    • Two 14.6 mm screws
    • One 6 mm screw
    • Use a Phillips screwdriver to loosen the captive screw.
    • Loosening this captive screw will pop up and separate the bottom-right corner of the back cover from the chassis.
    • During reassembly, tighten the captive screw before the rest of the screws.
  2. ASUS TUF Gaming F15 FX506L Left SSD Replacement, Release the clips: 2 단계, 이미지 1/2 ASUS TUF Gaming F15 FX506L Left SSD Replacement, Release the clips: 2 단계, 이미지 2/2
    • Insert an opening pick between the bottom-right corner of the back cover and the chassis, near the captive screw.
    • Pry up to release the clips securing the back cover.
    • You'll hear a click whenever a clip is released.
  3. ASUS TUF Gaming F15 FX506L Left SSD Replacement, Release the remaining clips: 3 단계, 이미지 1/3 ASUS TUF Gaming F15 FX506L Left SSD Replacement, Release the remaining clips: 3 단계, 이미지 2/3 ASUS TUF Gaming F15 FX506L Left SSD Replacement, Release the remaining clips: 3 단계, 이미지 3/3
    • Insert your opening pick again between the top-left corner of the back cover and the chassis.
    • Insert the pick at a steep angle. Pry up to release the remaining clips securing the back cover.
  4. ASUS TUF Gaming F15 FX506L Left SSD Replacement, Remove the back cover: 4 단계, 이미지 1/3 ASUS TUF Gaming F15 FX506L Left SSD Replacement, Remove the back cover: 4 단계, 이미지 2/3 ASUS TUF Gaming F15 FX506L Left SSD Replacement, Remove the back cover: 4 단계, 이미지 3/3
    • Lift the back cover off the chassis and remove it.
    • If your back cover is stuck to the chassis, use an opening pick to release the clips around the back cover's perimeter.
  5. ASUS TUF Gaming F15 FX506L Left SSD Replacement, Disconnect the battery: 5 단계, 이미지 1/3 ASUS TUF Gaming F15 FX506L Left SSD Replacement, Disconnect the battery: 5 단계, 이미지 2/3 ASUS TUF Gaming F15 FX506L Left SSD Replacement, Disconnect the battery: 5 단계, 이미지 3/3
    • Use the point of a spudger to push the sides of the battery connector out of its socket.
    • Push on alternating sides to 'walk' the connector out.
  6. ASUS TUF Gaming F15 FX506L Left SSD Replacement, Unfasten the SSD: 6 단계, 이미지 1/2 ASUS TUF Gaming F15 FX506L Left SSD Replacement, Unfasten the SSD: 6 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the 3.6 mm-long screw.
  7. ASUS TUF Gaming F15 FX506L Left SSD Replacement, Remove the SSD sleeve: 7 단계, 이미지 1/3 ASUS TUF Gaming F15 FX506L Left SSD Replacement, Remove the SSD sleeve: 7 단계, 이미지 2/3 ASUS TUF Gaming F15 FX506L Left SSD Replacement, Remove the SSD sleeve: 7 단계, 이미지 3/3
    • Grip the sleeve surrounding the SSD near the screw indent.
    • Pull the sleeve straight off the SSD and remove it.
  8. ASUS TUF Gaming F15 FX506L Left SSD Replacement, Remove the SSD: 8 단계, 이미지 1/3 ASUS TUF Gaming F15 FX506L Left SSD Replacement, Remove the SSD: 8 단계, 이미지 2/3 ASUS TUF Gaming F15 FX506L Left SSD Replacement, Remove the SSD: 8 단계, 이미지 3/3
    • Grip the edges of the SSD near the screw indent.
    • Pull it straight out of its socket and remove it.
    • If the SSD feels stuck, wiggle it side to side as you pull.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our ASUS TUF laptop answers community for help.
다른 3명이 해당 안내서를 완성하였습니다.
Clay Eickemeyer
회원 가입일: 09/19/22
70,408 평판
안내서 453개 작성하였습니다
iFixit iFixit 회원
Staff
140 회원들
안내서 18,086개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 55
30일 전: 245
전체 시간: 3,971
