주요 콘텐츠로 건너뛰기
ASUS TUF Gaming FX505DY Charging Port Replacement
필요한 것
  1. ASUS TUF Gaming FX505DY Charging Port Replacement, Back Case: 1 단계, 이미지 1/1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY Charging Port Replacement: 2 단계, 이미지 1/2 ASUS TUF Gaming FX505DY Charging Port Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY Charging Port Replacement: 3 단계, 이미지 1/2 ASUS TUF Gaming FX505DY Charging Port Replacement: 3 단계, 이미지 2/2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY Charging Port Replacement: 4 단계, 이미지 1/2 ASUS TUF Gaming FX505DY Charging Port Replacement: 4 단계, 이미지 2/2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
  5. ASUS TUF Gaming FX505DY Charging Port Replacement, Charging Port: 5 단계, 이미지 1/3 ASUS TUF Gaming FX505DY Charging Port Replacement, Charging Port: 5 단계, 이미지 2/3 ASUS TUF Gaming FX505DY Charging Port Replacement, Charging Port: 5 단계, 이미지 3/3
    • Using an ESD-safe spudger, disconnect the charging port connector by pulling the plug away from its port.
  6. ASUS TUF Gaming FX505DY Charging Port Replacement: 6 단계, 이미지 1/2 ASUS TUF Gaming FX505DY Charging Port Replacement: 6 단계, 이미지 2/2
    • Remove the two 6mm screws holding the screen hinge and charging port in place using a Phillips #1 screwdriver.
  7. ASUS TUF Gaming FX505DY Charging Port Replacement: 7 단계, 이미지 1/3 ASUS TUF Gaming FX505DY Charging Port Replacement: 7 단계, 이미지 2/3 ASUS TUF Gaming FX505DY Charging Port Replacement: 7 단계, 이미지 3/3
    • Firmly lift the screen hinge out of the way.
    • The hinge supports the weight of the screen, so it is stiff. Use consistent force.
  8. ASUS TUF Gaming FX505DY Charging Port Replacement: 8 단계, 이미지 1/1
    • Remove the charging port by lifting it free of the hole in the case.
    • It may require some shifting or angling to come free.
결론
Benyamin Claxton
회원 가입일: 03/27/22
776 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 2-4, Mellen Spring 2022 UMass Dartmouth, Team 2-4, Mellen Spring 2022 회원
UMASSD-MELLEN-S22S2G4
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 60
전체 시간: 1,859
