주요 콘텐츠로 건너뛰기
ASUS TUF Gaming FX505DY Solid State Drive Replacement
필요한 것
  1. ASUS TUF Gaming FX505DY Solid State Drive Replacement, Back Case: 1 단계, 이미지 1/1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY Solid State Drive Replacement: 2 단계, 이미지 1/2 ASUS TUF Gaming FX505DY Solid State Drive Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY Solid State Drive Replacement: 3 단계, 이미지 1/2 ASUS TUF Gaming FX505DY Solid State Drive Replacement: 3 단계, 이미지 2/2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY Solid State Drive Replacement: 4 단계, 이미지 1/2 ASUS TUF Gaming FX505DY Solid State Drive Replacement: 4 단계, 이미지 2/2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
  5. ASUS TUF Gaming FX505DY Solid State Drive Replacement, Solid State Drive: 5 단계, 이미지 1/2 ASUS TUF Gaming FX505DY Solid State Drive Replacement, Solid State Drive: 5 단계, 이미지 2/2
    • Remove the two 3 mm screws holding the solid state drive and its foil wrap in place using a Phillips #1 screwdriver.
    • The drive will pop up at an angle.
  6. ASUS TUF Gaming FX505DY Solid State Drive Replacement: 6 단계, 이미지 1/3 ASUS TUF Gaming FX505DY Solid State Drive Replacement: 6 단계, 이미지 2/3 ASUS TUF Gaming FX505DY Solid State Drive Replacement: 6 단계, 이미지 3/3
    • Slide the foil wrap off of the drive.
  7. ASUS TUF Gaming FX505DY Solid State Drive Replacement: 7 단계, 이미지 1/2 ASUS TUF Gaming FX505DY Solid State Drive Replacement: 7 단계, 이미지 2/2
    • Remove the solid state drive by pulling it at an angle from the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Benyamin Claxton
회원 가입일: 03/27/22
776 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 2-4, Mellen Spring 2022 UMass Dartmouth, Team 2-4, Mellen Spring 2022 회원
UMASSD-MELLEN-S22S2G4
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 27
전체 시간: 968
