주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS Transformer Book Flip TP500LA Battery Replacement
필요한 것
  1. ASUS Transformer Book Flip TP500LA Battery Replacement, Back Case: 1 단계, 이미지 3개 중 1개 ASUS Transformer Book Flip TP500LA Battery Replacement, Back Case: 1 단계, 이미지 3개 중 2개 ASUS Transformer Book Flip TP500LA Battery Replacement, Back Case: 1 단계, 이미지 3개 중 3개
    • Remove the ten 10 mm Phillips #0 screws found on the computer's back case.
  2. ASUS Transformer Book Flip TP500LA Battery Replacement: 2 단계, 이미지 2개 중 1개 ASUS Transformer Book Flip TP500LA Battery Replacement: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Heavy-Duty Spudger
    • Slide a heavy-duty spudger between the back case and the computer.
    • Slowly work around the edges to undo the clips to fully separate the back case from the computer.
    • Gently lift off the back case.
  3. ASUS Transformer Book Flip TP500LA Battery Replacement, Battery: 3 단계, 이미지 2개 중 1개 ASUS Transformer Book Flip TP500LA Battery Replacement, Battery: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Heavy-Duty Spudger
    • Slide a heavy-duty spudger into the ZIF connector and gently flip up the retaining flap to open the connector.
    • Pull the blue tab to remove the ribbon.
  4. ASUS Transformer Book Flip TP500LA Battery Replacement: 4 단계, 이미지 2개 중 1개 ASUS Transformer Book Flip TP500LA Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the three 5 mm Phillips #0 screws.
    • Remove the single 6 mm Phillips #0 screw.
  5. ASUS Transformer Book Flip TP500LA Battery Replacement: 5 단계, 이미지 2개 중 1개 ASUS Transformer Book Flip TP500LA Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Use the heavy-duty spudger to pry the white 8-pin connector away from the motherboard.
    • Gently pull the connector away from the motherboard.
    • The black 8-pin connector on the motherboard is very fragile, so be careful when removing the white 8-pin connector.
  6. ASUS Transformer Book Flip TP500LA Battery Replacement: 6 단계, 이미지 2개 중 1개 ASUS Transformer Book Flip TP500LA Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Use the blue plastic opening tool to loosen and remove the three black wires from the battery.
    • Slide the battery out from the computer to remove.
결론
다른 16명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Garrett Fitzpatrick
회원 가입일: 04/10/17
892 평판
안내서 2개를 작성함
Cal Poly, Team S13-G5, Forte Spring 2017 Cal Poly, Team S13-G5, Forte Spring 2017 회원
CPSU-FORTE-S17S13G5
3 회원들
안내서 6개를 작성함
1가이드 댓글
Power not responding?
Tamer Elhelaly - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 53
전체 시간: 12,000
