주요 콘텐츠로 건너뛰기
ASUS Transformer Book Flip TP500LA Speakers Replacement
필요한 것
  1. ASUS Transformer Book Flip TP500LA Speakers Replacement, Back Case: 1 단계, 이미지 1/3 ASUS Transformer Book Flip TP500LA Speakers Replacement, Back Case: 1 단계, 이미지 2/3 ASUS Transformer Book Flip TP500LA Speakers Replacement, Back Case: 1 단계, 이미지 3/3
    • Remove the ten 10 mm Phillips #0 screws found on the computer's back case.
  2. ASUS Transformer Book Flip TP500LA Speakers Replacement: 2 단계, 이미지 1/2 ASUS Transformer Book Flip TP500LA Speakers Replacement: 2 단계, 이미지 2/2
    • Slide a heavy-duty spudger between the back case and the computer.
    • Slowly work around the edges to undo the clips to fully separate the back case from the computer.
    • Gently lift off the back case.
  3. ASUS Transformer Book Flip TP500LA Speakers Replacement, Speakers: 3 단계, 이미지 1/3 ASUS Transformer Book Flip TP500LA Speakers Replacement, Speakers: 3 단계, 이미지 2/3 ASUS Transformer Book Flip TP500LA Speakers Replacement, Speakers: 3 단계, 이미지 3/3
    • Using a spudger or an opening tool, lift up each speaker to remove them from the device,
  4. ASUS Transformer Book Flip TP500LA Speakers Replacement: 4 단계, 이미지 1/1
    • Disconnect the speakers and remove them from the device.
결론
Graham Haigood
회원 가입일: 02/23/21
253 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 13
전체 시간: 375
