주요 콘텐츠로 건너뛰기
ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement
필요한 것
  1. ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement, USB and Power Circuit Board: 1 단계, 이미지 1/2 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement, USB and Power Circuit Board: 1 단계, 이미지 2/2
    • Remove the ten 10.7 mm screws using a Phillips #0 screwdriver from the back of the laptop.
  2. ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: 2 단계, 이미지 1/2 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: 2 단계, 이미지 2/2
    • Using a heavy-duty spudger, pry the back cover up from the frame and completely remove.
  3. ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: 3 단계, 이미지 1/2 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: 3 단계, 이미지 2/2
    • Remove the two 4.7 mm screws with the Phillips #0 screwdriver.
  4. ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: 4 단계, 이미지 1/3 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: 4 단계, 이미지 2/3 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: 4 단계, 이미지 3/3
    • Using a spudger or fingernail, flip up the white plastic latch securing the ribbon cable.
    • After the latch is released remove the ribbon cable and clear it from the board.
  5. ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: 5 단계, 이미지 1/2 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: 5 단계, 이미지 2/2
    • Remove the board itself by carefully pulling the board up then away from the rest of the computer.
결론
Wyatt Scott
회원 가입일: 11/01/18
136 평판
안내서 1개 작성함
IUPUI, Team S2-G3, Harley Fall 2018 IUPUI, Team S2-G3, Harley Fall 2018 회원
IUPUI-HARLEY-F18S2G3
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 8
전체 시간: 981
