주요 콘텐츠로 건너뛰기
ASUS U30SD-XA1 RAM Replacement
필요한 것
  1. ASUS U30SD-XA1 RAM Replacement, RAM: 1 단계, 이미지 1개 중 1개
    • Before removing the RAM, shut down your laptop and unplug the power adapter.
    • Turn the laptop over onto a flat surface.
  2. ASUS U30SD-XA1 RAM Replacement: 2 단계, 이미지 1개 중 1개
    • At the top center on the back of the device, you will see a small square panel.
    • Use a Phillips screwdriver to remove two screws located on the panel.
  3. ASUS U30SD-XA1 RAM Replacement: 3 단계, 이미지 2개 중 1개 ASUS U30SD-XA1 RAM Replacement: 3 단계, 이미지 2개 중 2개
    • Ground yourself from electrostatic discharge by touching any metal objects or use your anti-static gloves.
    • System memories are very sensitive to static electricity.
    • Push apart the latches on either side of the slot that hold the RAM in place, but gently.
    • Use firm pressure as needed. You will hear the RAM pop out of the slot.
    • Take the RAM stick out carefully, and set it aside on an anti-static surface.
  4. ASUS U30SD-XA1 RAM Replacement: 4 단계, 이미지 1개 중 1개
    • To replace the RAM, take and hold the new RAM by the sides, with the gold edge facing down towards the device.
    • Make sure your hands are clean and do not let your fingerprints get on the memory.
    • Line up the top corners of the new RAM with the top edges of the now empty panel.
    • Slide the RAM into the slot until it's firmly in place.
    • Once you hear the RAM stick click into place, you'll know you did it correctly.
    • Now just screw the panel door back on and you're finished!
결론
Your new ASUS U30SD-XA1 RAM is ready to go. Now your device should run and work faster!
다른 2명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Julie M Paul
회원 가입일: 07/17/15
171 평판
안내서 1개를 작성함
Texas Tech, Team 3-1, Rauch SU 2015 Texas Tech, Team 3-1, Rauch SU 2015 회원
TTU-RAUCH-SU15S3G1
3 회원들
안내서 1개 작성
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 12
지난 30일: 49
전체 시간: 1,797
