주요 콘텐츠로 건너뛰기
ASUS U52F-BBG6 Camera Replacement
필요한 것
  1. ASUS U52F-BBG6 Camera Replacement, Camera: 1 단계, 이미지 1/2 ASUS U52F-BBG6 Camera Replacement, Camera: 1 단계, 이미지 2/2
    • Scrape off the black circle rubber cushions with your index finger at the bottom frame of the screen.
    • The cushions may no longer be adherent and a bit of glue may be needed to reattach them.
    • Unscrew the two 3mm Phillips screws on the bottom of the frame with the J1 screwdriver.
    • The two 3mm Phillips screws are hidden behind the cushions.
  2. ASUS U52F-BBG6 Camera Replacement: 2 단계, 이미지 1/2 ASUS U52F-BBG6 Camera Replacement: 2 단계, 이미지 2/2
    • Insert the plastic opening tool into the crack where the plastic of the screen's frame meets the shell at the top.
    • Be careful not to scratch the screen with the opening tool.
    • Gently twist and slide the tool to open it. The plastic will snap as the frame is released.
    • The snaps that hold the frame to the shell are fragile.
    • Continue to pry with the opening tool or use your fingers until the top portion of the frame releases.
  3. ASUS U52F-BBG6 Camera Replacement: 3 단계, 이미지 1/2 ASUS U52F-BBG6 Camera Replacement: 3 단계, 이미지 2/2
    • Pull the screen frame towards you so that the seam between the frame and the bottom of the screen is opened.
    • Insert the opening tool into the seam.
    • Peel the metallic strip with your finger and thumb until it's fully off.
    • Place the remaining frame down on the keyboard.
  4. ASUS U52F-BBG6 Camera Replacement: 4 단계, 이미지 1/2 ASUS U52F-BBG6 Camera Replacement: 4 단계, 이미지 2/2
    • Use the pointed side of the black spudger to remove the metallic stickers by the circuit board of the camera above the screen.
    • Do not remove the sticker completely.
  5. ASUS U52F-BBG6 Camera Replacement: 5 단계, 이미지 1/2 ASUS U52F-BBG6 Camera Replacement: 5 단계, 이미지 2/2
    • Carefully lift the camera's circuit board by using the flat side of the spudger.
    • The adherent on the camera's circuit board is very sticky.
  6. ASUS U52F-BBG6 Camera Replacement: 6 단계, 이미지 1/2 ASUS U52F-BBG6 Camera Replacement: 6 단계, 이미지 2/2
    • Holding the camera's circuit board with your right hand, use your left index finger and thumb to unplug the micro white hook from the camera.
    • The micro white hook is fragile.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ashley DeHuff
회원 가입일: 09/15/16
852 평판
안내서 8개 작성하였습니다
CSU Fullerton, Team 1-3, Bruce Fall 2016 CSU Fullerton, Team 1-3, Bruce Fall 2016 회원
CSUF-BRUCE-F16S1G3
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 15
전체 시간: 252
