소개
This guide will inform you on how to replace your hard drive. This replacement will be very easy as there are only a few screws that need to be taken out during this guide to access and remove the hard drive.
필요한 것
Turn the laptop over to the back.
Unscrew the two 3mm Phillips screws using a PH0 screwdriver.
Lift the small black panel upward by putting your fingernail in the provided slot.
거의 끝나갑니다!
결론
