주요 콘텐츠로 건너뛰기
ASUS U52F-BBG6 Random Access Memory (RAM) Replacement
필요한 것
  1. ASUS U52F-BBG6 Random Access Memory (RAM) Replacement, Random Access Memory (RAM): 1 단계, 이미지 1/2 ASUS U52F-BBG6 Random Access Memory (RAM) Replacement, Random Access Memory (RAM): 1 단계, 이미지 2/2
    • Unscrew the two 3mm Phillips screws with the PH0 screwdriver.
    • Unhook the back panel by inserting your fingernail in the slot provided.
    • Lift the panel upward.
  2. ASUS U52F-BBG6 Random Access Memory (RAM) Replacement: 2 단계, 이미지 1/2 ASUS U52F-BBG6 Random Access Memory (RAM) Replacement: 2 단계, 이미지 2/2
    • Use both hands to pull the gold prongs outward.
    • Be careful not to get pinched as the RAM will spring upwards when released.
    • Lift the RAM out.
결론
Ashley DeHuff
회원 가입일: 09/15/16
852 평판
안내서 8개 작성하였습니다
CSU Fullerton, Team 1-3, Bruce Fall 2016 CSU Fullerton, Team 1-3, Bruce Fall 2016 회원
CSUF-BRUCE-F16S1G3
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 467
