주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS U52F-BBG6 Screen Replacement
필요한 것
  1. ASUS U52F-BBG6 Screen Replacement, Screen: 1 단계, 이미지 3개 중 1개 ASUS U52F-BBG6 Screen Replacement, Screen: 1 단계, 이미지 3개 중 2개 ASUS U52F-BBG6 Screen Replacement, Screen: 1 단계, 이미지 3개 중 3개
    • Scrape off the black circle rubber cushions with your index finger at the bottom frame of the screen.
    • The cushions may no longer be adherent and a bit of glue may be needed to reattach them.
    • Unscrew the two 3mm Phillips screws that were hidden under the cushions using J1 screwdriver.
  2. ASUS U52F-BBG6 Screen Replacement: 2 단계, 이미지 2개 중 1개 ASUS U52F-BBG6 Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Insert the plastic opening tool into the crack where the plastic of the screen's frame meets the shell at the top.
    • Be careful not to scratch the screen with the opening tool.
    • Gently twist and slide the tool to open it. The plastic will snap as the frame is released.
    • The snaps that hold the frame to the shell are fragile.
    • Continue to pry with the tool or use your fingers until the top portion of the frame is released.
    • Pull the screen frame towards you so that the seam between the frame and the screen is opened.
  3. ASUS U52F-BBG6 Screen Replacement: 3 단계, 이미지 2개 중 1개 ASUS U52F-BBG6 Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Insert the opening tool into the seam.
    • Try not to scratch the screen with the opening tool.
    • Pry the frame with the opening tool as shown in step 2.
    • Peel off the metallic tape that's attached to the bottom of the frame inside of the shell.
  4. ASUS U52F-BBG6 Screen Replacement: 4 단계, 이미지 2개 중 1개 ASUS U52F-BBG6 Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Unscrew the four 3mm Phillips screws with the J0 screwdriver on each corner of the screen.
  5. ASUS U52F-BBG6 Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Peel off the metallic tape on the top right side of the screen.
  6. ASUS U52F-BBG6 Screen Replacement: 6 단계, 이미지 2개 중 1개 ASUS U52F-BBG6 Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Lay the screen down flat on the keyboard.
    • Peel the yellow tape and then the metallic tape holding the screen's connection to the computer.
    • The metallic tape is hidden underneath the yellow tape.
  7. ASUS U52F-BBG6 Screen Replacement: 7 단계, 이미지 3개 중 1개 ASUS U52F-BBG6 Screen Replacement: 7 단계, 이미지 3개 중 2개 ASUS U52F-BBG6 Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Unlatch the golden connector under the metallic tape using the flat side of the nylon spudger.
    • Gently lift the connector and peel the metallic tape to detach the wire on your right that holds it in place.
    • Lift the now freed screen.
결론
작성자
4다른 기여자 명과 함께
Ashley DeHuff
회원 가입일: 09/15/16
852 평판
안내서 8개를 작성함
CSU Fullerton, Team 1-3, Bruce Fall 2016 CSU Fullerton, Team 1-3, Bruce Fall 2016 회원
CSUF-BRUCE-F16S1G3
4 회원들
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 44
전체 시간: 652
