소개
Use this guide to replace your Wi-Fi chip. Keep in mind it will take a lot of effort when removing the back panel.
필요한 것
Flip the laptop over to the back.
Slide the right latch to unlock, then simultaneously slide the left latch outward while pulling the battery out.
Insert and gently twist the flat metal spudger between the keyboard assembly and the bottom plastic cover so that a small seam is opened.
Put in the metal spudger in the seam to hold its place while twisting and levering the flat metal spudger along the whole keyboard.
Slowly pry off the back
Unlatch the clip attaching the white flattened flexible cord with a blue tip to the circuit board with your thumb.
Pull out the white flattened cord.
Find the Wi-Fi chip circuit board, which has a white sticker on it and is connected to a black and white wire.
다른 한 분이 해당 안내서를 완성하였습니다.
