주요 콘텐츠로 건너뛰기
ASUS U57A-BBL4 Display Assembly Replacement
필요한 것
  1. ASUS U57A-BBL4 Display Assembly Replacement, Display Assembly: 1 단계, 이미지 1/2 ASUS U57A-BBL4 Display Assembly Replacement, Display Assembly: 1 단계, 이미지 2/2
    • Carefully pry the two rubber covers at the bottom of the screen off with a metal sprudger.
  2. ASUS U57A-BBL4 Display Assembly Replacement: 2 단계, 이미지 1/1
    • Remove the two 1.84 mm Phillips head screws at the bottom of the screen using PH00 screw driver.
  3. ASUS U57A-BBL4 Display Assembly Replacement: 3 단계, 이미지 1/1
    • Starting from one of the corners, use your fingers to pry the bezel from the screen.
    • There is a popping sound when the bezel is loosened from the screen.
  4. ASUS U57A-BBL4 Display Assembly Replacement: 4 단계, 이미지 1/3 ASUS U57A-BBL4 Display Assembly Replacement: 4 단계, 이미지 2/3 ASUS U57A-BBL4 Display Assembly Replacement: 4 단계, 이미지 3/3
    • Remove the top two 2 mm Phillips head screws.
    • Remove the four 2 mm Phillips head screws on the bottom.
    • Remove the eight 2 mm Phillips head screws on the sides of the screen. There are four on each side.
    • There are 14 screws in total: two on the top, four on the bottom, and four on each side. Use PH00 screw-driver for removing all 14 screws.
  5. ASUS U57A-BBL4 Display Assembly Replacement: 5 단계, 이미지 1/2 ASUS U57A-BBL4 Display Assembly Replacement: 5 단계, 이미지 2/2
    • Don't tear off the bottom of the screen or you might damage the connector cable.
    • Carefully lower the screen from the casing with your fingers, making sure to keep the bottom intact and lay it face down on the keyboard.
  6. ASUS U57A-BBL4 Display Assembly Replacement: 6 단계, 이미지 1/2 ASUS U57A-BBL4 Display Assembly Replacement: 6 단계, 이미지 2/2
    • Disconnect the connector cable at the bottom by loosening the adhesive tape and lifting up.
    • Gently slide the cable out of the ridges to free the screen from the casing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Isabella Bernardi
회원 가입일: 10/18/17
671 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team S2-G4, Julie Fall 2017 UMass Dartmouth, Team S2-G4, Julie Fall 2017 회원
UMASSD-JULIE-F17S2G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 276
