주요 콘텐츠로 건너뛰기
ASUS U57A-BBL4 Motherboard Replacement
필요한 것
  1. ASUS U57A-BBL4 Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the laptop is completely shut down to avoid data complications.
    • Hold the left lock switch towards the left to the unlock option.
  2. ASUS U57A-BBL4 Motherboard Replacement: 2 단계, 이미지 1/1
    • Toggle the right lock switch to the unlock option.
  3. ASUS U57A-BBL4 Motherboard Replacement: 3 단계, 이미지 1/1
    • Gently slide the battery out while still holding the left unlock switch.
  4. ASUS U57A-BBL4 Motherboard Replacement, Front Panel Assembly: 4 단계, 이미지 1/2 ASUS U57A-BBL4 Motherboard Replacement, Front Panel Assembly: 4 단계, 이미지 2/2
    • Remove the two 2 mm Phillips head screws on each side on the bottom using PH00 screw driver.
    • Remove the one 2 mm screw underneath the black cover in the middle using the same screw driver.
  5. ASUS U57A-BBL4 Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove the RAM by lifting up with your fingers and sliding it out towards you.
  6. ASUS U57A-BBL4 Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the three 2 mm Phillips head screws on the hard drive using PH00 screw driver.
    • Remove the remaining seven 1.8 mm Phillips head screws using the same screw driver.
  7. ASUS U57A-BBL4 Motherboard Replacement: 7 단계, 이미지 1/2 ASUS U57A-BBL4 Motherboard Replacement: 7 단계, 이미지 2/2
    • Remove the hard drive by sliding it to the left and lifting up.
  8. ASUS U57A-BBL4 Motherboard Replacement: 8 단계, 이미지 1/2 ASUS U57A-BBL4 Motherboard Replacement: 8 단계, 이미지 2/2
    • Remove the six 2 mm Phillips head screws on the top edge of the laptop using PH00 screw driver.
    • Flip the laptop right-side up and open the screen.
  9. ASUS U57A-BBL4 Motherboard Replacement: 9 단계, 이미지 1/3 ASUS U57A-BBL4 Motherboard Replacement: 9 단계, 이미지 2/3 ASUS U57A-BBL4 Motherboard Replacement: 9 단계, 이미지 3/3
    • Starting in a corner of the keyboard, pry the keyboard from the laptop using a plastic opening tool.
    • Remove the ribbon cable on the bottom of the keyboard by lifting up on the tape and pulling up.
    • The front panel is now loose from the laptop.
  10. ASUS U57A-BBL4 Motherboard Replacement, Optical Drive: 10 단계, 이미지 1/1
    • Slide the optical drive out. It should easily come out.
  11. ASUS U57A-BBL4 Motherboard Replacement, Motherboard: 11 단계, 이미지 1/1
    • Remove the four 2 mm Phillips head screws from the top of the motherboard and fan using PH #1 screwdriver.
  12. ASUS U57A-BBL4 Motherboard Replacement: 12 단계, 이미지 1/2 ASUS U57A-BBL4 Motherboard Replacement: 12 단계, 이미지 2/2
    • Remove the blue cable on the bottom right by lifting up on the tab and pulling the cable out.
  13. ASUS U57A-BBL4 Motherboard Replacement: 13 단계, 이미지 1/3 ASUS U57A-BBL4 Motherboard Replacement: 13 단계, 이미지 2/3 ASUS U57A-BBL4 Motherboard Replacement: 13 단계, 이미지 3/3
    • Peel off the black and yellow tape attaching the fan to the base.
    • Peel the tape off the yellow cable and pull out to remove the cable.
    • Remove the small black, white and red cable next to the yellow cable at the top.
  14. ASUS U57A-BBL4 Motherboard Replacement: 14 단계, 이미지 1/1
    • Carefully and slowly lift up the motherboard from the base and remove the red and black cable underneath the motherboard in the top left corner near the fan.
    • The motherboard and fan are still attached to each other, but are loose from the base.
  15. ASUS U57A-BBL4 Motherboard Replacement: 15 단계, 이미지 1/1
    • Remove the four 2 mm Phillips head screws surrounding the copper rod using PH1 screw driver.
  16. ASUS U57A-BBL4 Motherboard Replacement: 16 단계, 이미지 1/1
    • Remove the red, blue, black and yellow cable attaching the fan and motherboard together with your fingers.
    • Now the motherboard and fan are completely separate from each other.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Isabella Bernardi
회원 가입일: 10/18/17
671 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team S2-G4, Julie Fall 2017 UMass Dartmouth, Team S2-G4, Julie Fall 2017 회원
UMASSD-JULIE-F17S2G4
3 회원들
안내서 6개 작성하였습니다
댓글 2개
Awesome! I have this exact computer mentioned (u57a bbL4) and am having the same problems you've mentioned, so I'm considering buying and replacing the motherboard. I noticed that there is a U57A k554 motherboard, not sure but is this an upgrade? Is there a motherboard that is an upgrade all the while fitting all of the other specifications for the elements? cpu, ram, hd etc? I am going to get a motherboard and a ssd .
Thanks for the info!
Dave C - 답글
I am not sure about the U57A K554 being the upgrade to the previous one but since it has the same series it should not be a problem.
Welcome
Brijesh Patel - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 1,173
