주요 콘텐츠로 건너뛰기
ASUS U57A-BBL4 Optical Drive Replacement
필요한 것
  1. ASUS U57A-BBL4 Optical Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the laptop is completely shut down to avoid data complications.
    • Hold the left lock switch towards the left to the unlock option.
  2. ASUS U57A-BBL4 Optical Drive Replacement: 2 단계, 이미지 1/1
    • Toggle the right lock switch to the unlock option.
  3. ASUS U57A-BBL4 Optical Drive Replacement: 3 단계, 이미지 1/1
    • Gently slide the battery out while still holding the left unlock switch.
  4. ASUS U57A-BBL4 Optical Drive Replacement, Front Panel Assembly: 4 단계, 이미지 1/2 ASUS U57A-BBL4 Optical Drive Replacement, Front Panel Assembly: 4 단계, 이미지 2/2
    • Remove the two 2 mm Phillips head screws on each side on the bottom using PH00 screw driver.
    • Remove the one 2 mm screw underneath the black cover in the middle using the same screw driver.
  5. ASUS U57A-BBL4 Optical Drive Replacement: 5 단계, 이미지 1/1
    • Remove the RAM by lifting up with your fingers and sliding it out towards you.
  6. ASUS U57A-BBL4 Optical Drive Replacement: 6 단계, 이미지 1/1
    • Remove the three 2 mm Phillips head screws on the hard drive using PH00 screw driver.
    • Remove the remaining seven 1.8 mm Phillips head screws using the same screw driver.
  7. ASUS U57A-BBL4 Optical Drive Replacement: 7 단계, 이미지 1/2 ASUS U57A-BBL4 Optical Drive Replacement: 7 단계, 이미지 2/2
    • Remove the hard drive by sliding it to the left and lifting up.
  8. ASUS U57A-BBL4 Optical Drive Replacement: 8 단계, 이미지 1/2 ASUS U57A-BBL4 Optical Drive Replacement: 8 단계, 이미지 2/2
    • Remove the six 2 mm Phillips head screws on the top edge of the laptop using PH00 screw driver.
    • Flip the laptop right-side up and open the screen.
  9. ASUS U57A-BBL4 Optical Drive Replacement: 9 단계, 이미지 1/3 ASUS U57A-BBL4 Optical Drive Replacement: 9 단계, 이미지 2/3 ASUS U57A-BBL4 Optical Drive Replacement: 9 단계, 이미지 3/3
    • Starting in a corner of the keyboard, pry the keyboard from the laptop using a plastic opening tool.
    • Remove the ribbon cable on the bottom of the keyboard by lifting up on the tape and pulling up.
    • The front panel is now loose from the laptop.
  10. ASUS U57A-BBL4 Optical Drive Replacement, Optical Drive: 10 단계, 이미지 1/1
    • Slide the optical drive out. It should easily come out.
결론
Isabella Bernardi
회원 가입일: 10/18/17
671 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team S2-G4, Julie Fall 2017 UMass Dartmouth, Team S2-G4, Julie Fall 2017 회원
UMASSD-JULIE-F17S2G4
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
On my Asus U57A you only have to remove the one 2mm screw under the plastic cover on the bottom and the optical drive slides right out.  This seems like a considerable amount of overkill to me.
Steve Britten - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 315
