소개
If your laptop does not read CD's or DVD's properly, there might be a problem with the optical drive. The following guide will help you replace the optical drive.
필요한 것
Remove the two 2 mm Phillips head screws on each side on the bottom using PH00 screw driver.
Remove the one 2 mm screw underneath the black cover in the middle using the same screw driver.
댓글 한 개
On my Asus U57A you only have to remove the one 2mm screw under the plastic cover on the bottom and the optical drive slides right out. This seems like a considerable amount of overkill to me.
