주요 콘텐츠로 건너뛰기
ASUS VG248 Disassembly
필요한 것
  1. ASUS VG248 Disassembly, ASUS VG248 Disassembly: 1 단계, 이미지 1/2 ASUS VG248 Disassembly, ASUS VG248 Disassembly: 1 단계, 이미지 2/2
    • Before you begin, lay the monitor face down on a smooth, clean surface.
    • Four rubbery covers hide four screws in the rear of the monitor.
    • Pry out the plastic covers with a stiff pointed tool, like a metal spudger.
  2. ASUS VG248 Disassembly: 2 단계, 이미지 1/1
    • Remove the four 13.4 mm Philips #1 screws securing the monitor stand.
  3. ASUS VG248 Disassembly: 3 단계, 이미지 1/2 ASUS VG248 Disassembly: 3 단계, 이미지 2/2
    • Remove the stand from the display.
  4. ASUS VG248 Disassembly: 4 단계, 이미지 1/2 ASUS VG248 Disassembly: 4 단계, 이미지 2/2
    • The display bezel is held to the rear case by plastic clips that can be released by pulling straight up on the bezel.
    • Rather than use any prying tools that could damage the LCD, it's best to just pull with your fingers. A thin cloth will both protect your fingertips and prevent you from smudging the LCD.
    • Lay the cloth over one of the long edges of the display.
    • Grip the side of the bezel through the cloth and lift straight up. A few clips in the center will pop free.
    • Be careful to pull straight up, and not pry against the display. Pushing down on the display could damage it.
  5. ASUS VG248 Disassembly: 5 단계, 이미지 1/2 ASUS VG248 Disassembly: 5 단계, 이미지 2/2
    • Repeat the procedure around the display, lifting up the center of the next side.
  6. ASUS VG248 Disassembly: 6 단계, 이미지 1/2 ASUS VG248 Disassembly: 6 단계, 이미지 2/2
    • Move around to the other long side and lift up on the center of the bezel.
  7. ASUS VG248 Disassembly: 7 단계, 이미지 1/2 ASUS VG248 Disassembly: 7 단계, 이미지 2/2
    • Grip the center of the final side and lift the bezel away from the rear case.
  8. ASUS VG248 Disassembly: 8 단계, 이미지 1/2 ASUS VG248 Disassembly: 8 단계, 이미지 2/2
    • Now that you've freed the centers of the four sides, it's time to move on to the corners.
    • Each corner is secured by two large clips that can't be freed by just pulling straight up like you did with the sides.
    • In the next step, you'll be pushing in on the corner clip on the left of the bottom edge of the bezel.
  9. ASUS VG248 Disassembly: 9 단계, 이미지 1/2 ASUS VG248 Disassembly: 9 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Jimmy
    $7.95
    구매
    • Using a thin stiff prying device, like a Jimmy, press in against the bottom clip in the lower left corner (beneath the HDMI logo).
    • While pressing the clip in, pull up on the lower edge of the bezel. The entire corner should pop free.
  10. ASUS VG248 Disassembly: 10 단계, 이미지 1/3 ASUS VG248 Disassembly: 10 단계, 이미지 2/3 ASUS VG248 Disassembly: 10 단계, 이미지 3/3
    • Once you've freed one corner, you should be able to gently twist the bezel off, freeing all of the remaining corners.
    • If any corners are particularly stubborn, repeat the previous step on the difficult corner.
  11. ASUS VG248 Disassembly: 11 단계, 이미지 1/1
    • Remove the bezel.
  12. ASUS VG248 Disassembly: 12 단계, 이미지 1/2 ASUS VG248 Disassembly: 12 단계, 이미지 2/2
    • Lift the LCD out of the rear case.
    • The row of adjustment buttons will come out of the case with the display, attached by a thin ribbon cable. Take care not to damage the cable.
  13. ASUS VG248 Disassembly: 13 단계, 이미지 1/1
    • With the casing removed, you now have access to the button board, cables, and the housing over the motherboard components.
결론
다른 19명이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 10/18/12
465,777 평판
안내서 538개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 8개
Do you know of any place that sell the replacement lcd screen?
treymcbrd - 답글
Hi there, I have a little thunderbug trapped in the LCD is it possible to take the metal casing at the front of to reomve said bug? Thanks
TJ Grainger - 답글
You could yes, but be very careful NOT to introduce dust into the panel!
Bertus van den Dikkenberg -
Hi. A really small bug got stuck within my screen and I accidentally squished it so now it’s dead in there and I want to clean it. How would I remove the top layer of the screen? Because from what I can see it seems like it got squished between the glass and the actual LCD screen itself.
Carl Viernes - 답글
Guide to disassemble vg259qm
syedaliabdullah272 - 답글
What power adapter and power cord is for gaming monitor Asus vg245qg? It was losted during moving.
RICHARD GOVENOR - 답글
I have the same issue as TJ Grainger. I have a very tiny spider, about 1 CM big spider (I can see by how it moves and it's legs projected from a white background) behind my screen. This is going to be annoying...
Shelby Bainbridge - 답글
댓글 쓰기
조회 통계:
24 시간 전: 29
7일 전: 207
30일 전: 950
전체 시간: 114,893
