주요 콘텐츠로 건너뛰기
ASUS VivoBook Flip TP501U Keyboard Panel Replacement
필요한 것
  1. ASUS VivoBook Flip TP501U Keyboard Panel Replacement, Keyboard Panel: 1 단계, 이미지 1/2 ASUS VivoBook Flip TP501U Keyboard Panel Replacement, Keyboard Panel: 1 단계, 이미지 2/2
    • Open the laptop until it is flat and lay it screen down.
    • Remove eight 9.6mm Phillips #00 screws from the bottom of the laptop.
    • Remove two 4.8mm Phillips from the corners of the device.
  2. ASUS VivoBook Flip TP501U Keyboard Panel Replacement: 2 단계, 이미지 1/1
    • Turn the device face up.
    • Use the plastic Opening Pick to separate the keyboard panel from the chassis that was just unscrewed.
    • Pull the panel away from the chassis CAREFULLY, as there are ribbon cables attached between the keyboard and internal electronics.
  3. ASUS VivoBook Flip TP501U Keyboard Panel Replacement: 3 단계, 이미지 1/1
    • With the keyboard panel pulled up, detach the two ribbon cables from the motherboard using the blue tabs on the cables.
    • Remove the keyboard panel completely.
결론
Evan Grilley
회원 가입일: 01/14/20
233 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 15
전체 시간: 900
