주요 콘텐츠로 건너뛰기
ASUS VivoBook S300C Hard Drive Replacement
필요한 것
  1. ASUS VivoBook S300C Hard Drive Replacement, Remove the bottom cover: 1 단계, 이미지 1/1
    • Remove the 10 screws on the back cover.
    • Some screws are missing from this system. You should take your own notes to make sure you put the correct screws in during reassembly.
  2. ASUS VivoBook S300C Hard Drive Replacement, Remove the hard drive cable: 2 단계, 이미지 1/1
    • Remove the hard drive from the laptop. To do this, the cable is taped to the hard drive caddy. Remove the tape from the cable and disconnect the hard drive from the motherboard.
    • I am also missing screws here. Take your own notes to avoid misplacing screws during reassembly. They should all be the same length.
  3. ASUS VivoBook S300C Hard Drive Replacement, Remove the hard drive from the caddy: 3 단계, 이미지 1/2 ASUS VivoBook S300C Hard Drive Replacement, Remove the hard drive from the caddy: 3 단계, 이미지 2/2
    • Remove the 4 screws holding the hard drive in the caddy. There are two screws on each side.
    • Reassemble the laptop by following the steps in reverse order. This is my first guide, so let me know what I did wrong so I can fix it.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Cameron
회원 가입일: 12/02/15
10,353 평판
안내서 1개 작성함
Master Techs Master Techs 회원
Community
321 회원들
안내서 1,518개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 3,536
