주요 콘텐츠로 건너뛰기
ASUS VivoBook S300CA-BBI5T01 CMOS Battery Replacement
필요한 것
  1. ASUS VivoBook S300CA-BBI5T01 CMOS Battery Replacement, CMOS Battery: 1 단계, 이미지 1/1
    • Place the laptop upside down so that the bottom panel is facing upwards.
  2. ASUS VivoBook S300CA-BBI5T01 CMOS Battery Replacement: 2 단계, 이미지 1/1
    • Unscrew the following 10 screws
    • Eight 5 mm Phillips head srews
    • Two 10 mm Phillips head screws
  3. ASUS VivoBook S300CA-BBI5T01 CMOS Battery Replacement: 3 단계, 이미지 1/1
    • Carefully peel the panel off of the bottom of the laptop.
  4. ASUS VivoBook S300CA-BBI5T01 CMOS Battery Replacement: 4 단계, 이미지 1/1
    • Carefully remove the CMOS battery from its port by lifting it upward.
결론
Keith Rachels
회원 가입일: 03/04/16
595 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 3-4, Bhusal Spring 2016 UMass Dartmouth, Team 3-4, Bhusal Spring 2016 회원
UMASSD-BHUSAL-S16S3G4
2 회원들
안내서 5개 작성하였습니다
댓글 한 개
My computer hp power shutdown not open or not give any light how can I solve this problem
Amanuel Edosa - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 1,469
