주요 콘텐츠로 건너뛰기
ASUS VivoBook S400C Speaker Replacement
필요한 것
  1. ASUS VivoBook S400C Speaker Replacement, Remove the Bottom Cover: 1 단계, 이미지 1/1
    • Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
  2. ASUS VivoBook S400C Speaker Replacement: 2 단계, 이미지 1/2 ASUS VivoBook S400C Speaker Replacement: 2 단계, 이미지 2/2
    • Use a spudger or your fingers to go around and lift the edges and release the back panel.
  3. ASUS VivoBook S400C Speaker Replacement, Disconnect the Battery: 3 단계, 이미지 1/1
    • Using a spudger, lift up the plug connecting the battery to the motherboard.
  4. ASUS VivoBook S400C Speaker Replacement, Battery: 4 단계, 이미지 1/1
    • With a Phillips #0 screwdriver, remove the four 5.7 mm screws holding the battery to the laptop.
  5. ASUS VivoBook S400C Speaker Replacement: 5 단계, 이미지 1/1
    • Carefully lift the battery up and out of the device.
  6. ASUS VivoBook S400C Speaker Replacement, Hard Drive: 6 단계, 이미지 1/1
    • Remove the three Phillips #0 screws holding the the hard drive in place:
    • Two 3.8 mm screws.
    • One 5.7 mm screw.
  7. ASUS VivoBook S400C Speaker Replacement: 7 단계, 이미지 1/1
    • Pull left and lift out the hard drive.
  8. ASUS VivoBook S400C Speaker Replacement, LED Board: 8 단계, 이미지 1/3 ASUS VivoBook S400C Speaker Replacement, LED Board: 8 단계, 이미지 2/3 ASUS VivoBook S400C Speaker Replacement, LED Board: 8 단계, 이미지 3/3
    • Disconnect the ribbon cable connecting the LED daughterboard and the motherboard by lifting the white tab on the LED side of the cable.
  9. ASUS VivoBook S400C Speaker Replacement: 9 단계, 이미지 1/2 ASUS VivoBook S400C Speaker Replacement: 9 단계, 이미지 2/2
    • Pull out the ribbon cable on the LED side by pulling on the blue tab.
  10. ASUS VivoBook S400C Speaker Replacement: 10 단계, 이미지 1/3 ASUS VivoBook S400C Speaker Replacement: 10 단계, 이미지 2/3 ASUS VivoBook S400C Speaker Replacement: 10 단계, 이미지 3/3
    • The LED board is held in place by a hook on the left end and a latch on the right.
    • Press the latch with a spudger while lifting with a fingernail.
    • Pull the LED board to the right to clear the left-hand hook.
  11. ASUS VivoBook S400C Speaker Replacement, Speakers: 11 단계, 이미지 1/2 ASUS VivoBook S400C Speaker Replacement, Speakers: 11 단계, 이미지 2/2
    • Pull out the black cable connecting the motherboard to the speakers.
  12. ASUS VivoBook S400C Speaker Replacement: 12 단계, 이미지 1/2 ASUS VivoBook S400C Speaker Replacement: 12 단계, 이미지 2/2
    • Deroute the speaker wire from the motherboard to the left speaker.
  13. ASUS VivoBook S400C Speaker Replacement: 13 단계, 이미지 1/3 ASUS VivoBook S400C Speaker Replacement: 13 단계, 이미지 2/3 ASUS VivoBook S400C Speaker Replacement: 13 단계, 이미지 3/3
    • Using a metal opening tool, pry off the left speaker.
    • A fairly strong adhesive is used between the speakers and the body of the laptop, requiring considerable force to take apart. Work slowly and use caution when working near the delicate wires connecting the two speakers.
  14. ASUS VivoBook S400C Speaker Replacement: 14 단계, 이미지 1/2 ASUS VivoBook S400C Speaker Replacement: 14 단계, 이미지 2/2
    • Deroute the wires from the left speaker to the right.
  15. ASUS VivoBook S400C Speaker Replacement: 15 단계, 이미지 1/2 ASUS VivoBook S400C Speaker Replacement: 15 단계, 이미지 2/2
    • Continue to deroute the speaker wire to the right speaker.
  16. ASUS VivoBook S400C Speaker Replacement: 16 단계, 이미지 1/3 ASUS VivoBook S400C Speaker Replacement: 16 단계, 이미지 2/3 ASUS VivoBook S400C Speaker Replacement: 16 단계, 이미지 3/3
    • Using a metal opening tool, pry off the right speaker.
    • It bears repeating that a fairly strong adhesive is used between the speakers and the body of the laptop, requiring considerable force to take apart.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Bryan Chung
회원 가입일: 10/18/19
437 평판
안내서 4개 작성하였습니다
UC Santa Barbara, Team A-1, Bator Winter 2022 UC Santa Barbara, Team A-1, Bator Winter 2022 회원
UCSB-BATOR-W22SAG1
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 19
전체 시간: 1,019
