주요 콘텐츠로 건너뛰기
ASUS VivoBook S400C Wifi Card Replacement
필요한 것
  1. ASUS VivoBook S400C Wifi Card Replacement, Remove the Bottom Cover: 1 단계, 이미지 1/1
    • Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
  2. ASUS VivoBook S400C Wifi Card Replacement: 2 단계, 이미지 1/2 ASUS VivoBook S400C Wifi Card Replacement: 2 단계, 이미지 2/2
    • Use a spudger or your fingers to go around and lift the edges and release the back panel.
  3. ASUS VivoBook S400C Wifi Card Replacement, Disconnect the Battery: 3 단계, 이미지 1/1
    • Using a spudger, lift up the plug connecting the battery to the motherboard.
  4. ASUS VivoBook S400C Wifi Card Replacement, Wifi Card: 4 단계, 이미지 1/2 ASUS VivoBook S400C Wifi Card Replacement, Wifi Card: 4 단계, 이미지 2/2
    • Use a spudger to release the cables from the wifi card.
  5. ASUS VivoBook S400C Wifi Card Replacement: 5 단계, 이미지 1/1
    • Remove the singular 3.8 mm screw with a Phillips #0 screwdriver.
  6. ASUS VivoBook S400C Wifi Card Replacement: 6 단계, 이미지 1/1
    • Pull the wifi card up and out.
결론
Ashley Panduro
회원 가입일: 10/16/19
572 평판
안내서 3개 작성하였습니다
UC Santa Barbara, Team S4-G4, Bator Fall 2019 UC Santa Barbara, Team S4-G4, Bator Fall 2019 회원
UCSB-BATOR-F19S4G4
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 10
전체 시간: 750
