주요 콘텐츠로 건너뛰기
ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement
필요한 것
  1. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/3 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/3 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement, Hard Drive: 1 단계, 이미지 3/3
    • Flip the laptop onto its backside.
    • Use a Phillips #00 screwdriver to remove the nine 1.2 mm Phillips #00 screws screws attached to the laptop backing.
  2. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: 2 단계, 이미지 1/2 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: 2 단계, 이미지 2/2
    • Remove the laptop backing with a prying tool. Use the prying tool between the keyboard and bottom grooves.
    • Start prying from the center of the laptop and work your way around the edges of the laptop to remove the keyboard panel.
    • It is recommended to use a plastic prying tool versus a metal prying tool as it could scratch your laptop.
  3. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: 3 단계, 이미지 1/2 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: 3 단계, 이미지 2/2
    • Separate the laptop keyboard from the laptop backing.
    • Carefully remove the keyboard connector from the motherboard.
  4. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: 4 단계, 이미지 1/2 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: 4 단계, 이미지 2/2
    • Remove the two 3 mm screws attached to the laptop's hard drive metal cage using the Phillips #00 screwdriver.
    • Once the screws have been removed, gently disconnect the hard drive by pulling the hard drive away from the integrated SATA port.
  5. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: 5 단계, 이미지 1/2 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: 5 단계, 이미지 2/2
    • Remove the four 3 mm screws attached to hard drive metal cage using the Phillips #00 screwdriver.
    • Remove the hard drive from the bracket.
결론
다른 3명이 해당 안내서를 완성하였습니다.
David Nguyen
회원 가입일: 05/14/21
202 평판
안내서 1개 작성함
York University, Team S1-G18, Melo-Thaiss Summer 2021 York University, Team S1-G18, Melo-Thaiss Summer 2021 회원
YORK-MELO-THAISS-SU21S1G18
1 회원
안내서 1개 작성하였습니다
댓글 한 개
I replaced the original sata into a ssd but it doesnt boot to windows. It gets stuck in bios. The ssd has an os already. It appears in the storage section but not in the boot list. I have already tried to boot the ssd to my computer and it works.
Christusjohn Leoncio L Salvani - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 44
전체 시간: 1,704
