주요 콘텐츠로 건너뛰기
ASUS VivoTab Note 8 Motherboard Replacement
필요한 것
  1. ASUS VivoTab Note 8 Motherboard Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove the pen and memory card if you have them; they may get in the way when you are opening the device.
    • Pry open the edges of the cover using the plastic opening tool. The memory card slot is very useful for getting started.
  2. ASUS VivoTab Note 8 Motherboard Replacement: 2 단계, 이미지 1/2 ASUS VivoTab Note 8 Motherboard Replacement: 2 단계, 이미지 2/2
    • Move the opening tool along the edges of the tablet and push up wherever you can. You may need to open up all of the sides to take the panel off.
    • Pull apart the sides of the casing by hand.
  3. ASUS VivoTab Note 8 Motherboard Replacement: 3 단계, 이미지 1/1
    • After pulling the panel off, put it to the side.
  4. ASUS VivoTab Note 8 Motherboard Replacement, Motherboard: 4 단계, 이미지 1/1
    • Unplug the battery from the motherboard.
    • Lodge something (a fingernail works fine) under the connecting piece and apply a force straight up and perpendicular to the back of the device.
  5. ASUS VivoTab Note 8 Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove the screws from the black plastic restraint restricting the motherboard's movement using a Phillips #000 screwdriver.
    • Gently remove the black plastic restraint from the motherboard.
  6. ASUS VivoTab Note 8 Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the six screws holding the motherboard in place using a Phillips #000 screwdriver.
  7. ASUS VivoTab Note 8 Motherboard Replacement: 7 단계, 이미지 1/1
    • Gently pull out the remaining ribbons and cords still plugged into the motherboard.
    • Remove the motherboard from the device.
결론
Ryan Spencer
회원 가입일: 09/21/18
753 평판
안내서 6개 작성하였습니다
University of North Texas, Team 2-7, Raign Spring 2023 University of North Texas, Team 2-7, Raign Spring 2023 회원
UNT-RAIGN-S23S2G7
2 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 674
