주요 콘텐츠로 건너뛰기
ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement
필요한 것
  1. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement, Back Case Housing: 1 단계, 이미지 1/1
    • Remove all ten 6mm Phillips #1 screws from the bottom of the computer chassis.
  2. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: 2 단계, 이미지 1/1
    • Carefully pry open the back cover from the laptop and place it to the side.
  3. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement, Memory Card: 3 단계, 이미지 1/2 ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement, Memory Card: 3 단계, 이미지 2/2
    • Lift the perforated metal cover up from the motherboard to expose the memory cards.
  4. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: 4 단계, 이미지 1/2 ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: 4 단계, 이미지 2/2
    • Once the cover is removed the RAM will be accessible.
    • Use your fingertips to pry out the metal guards outlining both of the sides of the memory card.
    • The RAM stick should then pop up to rest at an angle to the motherboard.
  5. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: 5 단계, 이미지 1/1
    • Using your fingertips, slide the memory card out from the plastic housing and remove it from the board.
    • Be sure to remove the card at the same angle at which it rests to avoid damaging the card or the contacts of the slot.
결론
Mark Fanelli
회원 가입일: 04/09/19
97 평판
안내서 1개 작성함
IUPUI, Team S1-G2, Hovde Spring 2019 IUPUI, Team S1-G2, Hovde Spring 2019 회원
IUPUI-HOVDE-S19S1G2
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 425
