주요 콘텐츠로 건너뛰기
ASUS Vivobook Q301LA-BSI5T17 RAM Replacement
필요한 것
  1. ASUS Vivobook Q301LA-BSI5T17 RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Unscrew the (10) screws on the bottom of the computer chassis using the JIS #0 screwdriver.
  2. ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: 2 단계, 이미지 1/2 ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: 2 단계, 이미지 2/2
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: 3 단계, 이미지 1/3 ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: 3 단계, 이미지 2/3 ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: 3 단계, 이미지 3/3
    • Remove the (6) six screws attaching the battery to the frame using the JIS #0 screwdriver.
    • Use the black plastic spudger to remove the battery from the device.
  4. ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: 4 단계, 이미지 1/3 ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: 4 단계, 이미지 2/3 ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: 4 단계, 이미지 3/3
    • Gently take the battery out of the laptop, making sure that all wires connecting to it are disconnected.
  5. ASUS Vivobook Q301LA-BSI5T17 RAM Replacement, RAM: 5 단계, 이미지 1/2 ASUS Vivobook Q301LA-BSI5T17 RAM Replacement, RAM: 5 단계, 이미지 2/2
    • Gently pry this metal cover off the motherboard.
  6. ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: 6 단계, 이미지 1/3 ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: 6 단계, 이미지 2/3 ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: 6 단계, 이미지 3/3
    • Now the RAM stick is exposed. Using two fingers, gently push the buttons to release the RAM stick
  7. ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: 7 단계, 이미지 1/1
    • When you put in the new RAM, make sure to line up the connectors. Put the RAM in gently, as being rough with it can cause damage to the stick.
결론
Jens Peter Andersen
회원 가입일: 10/03/17
658 평판
안내서 6개 작성하였습니다
USF Tampa, Team S5-G1, Walkup Fall 2017 USF Tampa, Team S5-G1, Walkup Fall 2017 회원
USFT-WALKUP-F17S5G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 20
전체 시간: 1,337
