주요 콘텐츠로 건너뛰기
ASUS Vivobook S500CA Battery Replacement
필요한 것
  1. ASUS Vivobook S500CA Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the device over to where the back plate is facing up.
  2. ASUS Vivobook S500CA Battery Replacement: 2 단계, 이미지 1/1
    • Use a Philips Head PH1 screwdriver to remove 10 screws (3 1cm screws and 7 .5cm screws) around the perimeter of the back plate.
    • Place screws where they cannot be lost as they will be used to replace the back plate.
  3. ASUS Vivobook S500CA Battery Replacement: 3 단계, 이미지 1/1
    • Remove the back plate by lifting it straight up.
  4. ASUS Vivobook S500CA Battery Replacement: 4 단계, 이미지 1/1
    • Remove 9 (.5 cm) phillips screws around the edge of the battery.
  5. ASUS Vivobook S500CA Battery Replacement: 5 단계, 이미지 1/1
    • Lift up the battery to reveal the battery terminal.
  6. ASUS Vivobook S500CA Battery Replacement: 6 단계, 이미지 1/1
    • Unclip the battery terminal by prying straight up on the sides of the connector to release the clip.
결론
Deric Huffman
회원 가입일: 01/17/17
101 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 6,012
