주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
ASUS X42J IO Board Replacement
필요한 것
  1. ASUS X42J IO Board Replacement, Keyboard: 1 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Metal Spudger
    $2.99
    구매
    • Make sure your device is unplugged and turned off before proceeding.
    • Using a Spudger, gently pry up the keyboard.
  2. ASUS X42J IO Board Replacement: 2 단계, 이미지 1/2 ASUS X42J IO Board Replacement: 2 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Nylon Tipped Tweezers
    구매
    • Rotate the keyboard to face downward.
    • Pull out the blue wiring connection. Use tweezers to make it easier to remove.
  3. ASUS X42J IO Board Replacement, Disk Drive: 3 단계, 이미지 1/1
    • Use the Phillips #0 screwdriver to remove the two screws on the back of the laptop.
  4. ASUS X42J IO Board Replacement: 4 단계, 이미지 1/1
    • Slide the disk drive out of the device.
  5. ASUS X42J IO Board Replacement, Motherboard: 5 단계, 이미지 1/3 ASUS X42J IO Board Replacement, Motherboard: 5 단계, 이미지 2/3 ASUS X42J IO Board Replacement, Motherboard: 5 단계, 이미지 3/3
    • Remove all screws located on the bottom plate of the laptop, beginning with the three located underneath the disc drive.
  6. ASUS X42J IO Board Replacement: 6 단계, 이미지 1/2 ASUS X42J IO Board Replacement: 6 단계, 이미지 2/2
    • Rotate the laptop until it is sitting face up and extract all screws exposed by removing the keyboard.
  7. ASUS X42J IO Board Replacement: 7 단계, 이미지 1/2 ASUS X42J IO Board Replacement: 7 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Metal Spudger
    $2.99
    구매
    • Pull up on the front panel using the spudger until the front panel separates from the bottom panel.
  8. ASUS X42J IO Board Replacement: 8 단계, 이미지 1/1
    • Unscrew and remove the marked screws.
  9. ASUS X42J IO Board Replacement: 9 단계, 이미지 1/1
    • Separate the connectors.
  10. ASUS X42J IO Board Replacement: 10 단계, 이미지 1/2 ASUS X42J IO Board Replacement: 10 단계, 이미지 2/2
    • Remove the motherboard from the device.
  11. ASUS X42J IO Board Replacement, IO Board: 11 단계, 이미지 1/2 ASUS X42J IO Board Replacement, IO Board: 11 단계, 이미지 2/2
    • Remove the tape from the screen connector.
    • Remove the screws from the connector.
  12. ASUS X42J IO Board Replacement: 12 단계, 이미지 1/1
    • Pull the screen away from the mount.
  13. ASUS X42J IO Board Replacement: 13 단계, 이미지 1/1
    • Pull the IO board off of the mount.
결론
Connor Pelis
회원 가입일: 09/21/18
253 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 264
