소개
The screen is one of the most important parts of a laptop, as you won't be able to see anything you're doing without it, which is kind of the point. The disassembly isn't too complicated, there's just a lot of screws that need to be removed.
필요한 것
Use the Phillips #0 screwdriver to remove the two screws on the back of the laptop.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
