주요 콘텐츠로 건너뛰기
ASUS X44H-BBR4 Front Panel Replacement
필요한 것
  1. ASUS X44H-BBR4 Front Panel Replacement, Battery: 1 단계, 이미지 1/2 ASUS X44H-BBR4 Front Panel Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the device over.
  2. ASUS X44H-BBR4 Front Panel Replacement: 2 단계, 이미지 1/3 ASUS X44H-BBR4 Front Panel Replacement: 2 단계, 이미지 2/3 ASUS X44H-BBR4 Front Panel Replacement: 2 단계, 이미지 3/3
    • Slide the right lock button to the unlock position.
    • After it is unlocked, a red line will be visible.
  3. ASUS X44H-BBR4 Front Panel Replacement: 3 단계, 이미지 1/2 ASUS X44H-BBR4 Front Panel Replacement: 3 단계, 이미지 2/2
    • Slide the left lock button into the unlock position and hold.
  4. ASUS X44H-BBR4 Front Panel Replacement: 4 단계, 이미지 1/3 ASUS X44H-BBR4 Front Panel Replacement: 4 단계, 이미지 2/3 ASUS X44H-BBR4 Front Panel Replacement: 4 단계, 이미지 3/3
    • While holding the left lock button in the unlock position, push the battery from the center away from you.
  5. ASUS X44H-BBR4 Front Panel Replacement, Keyboard: 5 단계, 이미지 1/2 ASUS X44H-BBR4 Front Panel Replacement, Keyboard: 5 단계, 이미지 2/2
    • Open the laptop to show the keyboard.
  6. ASUS X44H-BBR4 Front Panel Replacement: 6 단계, 이미지 1/1
    • Look at the top row of the keyboard, you will see a space that has four latches holding the keyboard down.
    • The latches are located above the Esc key, the F5 key, between the F10 and F11 key and the Delete key.
  7. ASUS X44H-BBR4 Front Panel Replacement: 7 단계, 이미지 1/3 ASUS X44H-BBR4 Front Panel Replacement: 7 단계, 이미지 2/3 ASUS X44H-BBR4 Front Panel Replacement: 7 단계, 이미지 3/3
    • Don't pull too hard on the keys otherwise they may fall off.
    • Push the latch away from the keyboard using the spudger point.
    • While pushing the latches use a plastic opening tool and pull up on a key near it.
    • Continue along the rest of the keyboard until it is released at all four latches.
  8. ASUS X44H-BBR4 Front Panel Replacement: 8 단계, 이미지 1/2 ASUS X44H-BBR4 Front Panel Replacement: 8 단계, 이미지 2/2
    • Push the keyboard away from the mouse track pad to unlock the bottom from the base.
    • Do not pull too hard because there is a ribbon connecting to keyboard to the motherboard.
  9. ASUS X44H-BBR4 Front Panel Replacement: 9 단계, 이미지 1/2 ASUS X44H-BBR4 Front Panel Replacement: 9 단계, 이미지 2/2
    • Flip the keyboard over to reveal the back of it and what is underneath.
  10. ASUS X44H-BBR4 Front Panel Replacement: 10 단계, 이미지 1/3 ASUS X44H-BBR4 Front Panel Replacement: 10 단계, 이미지 2/3 ASUS X44H-BBR4 Front Panel Replacement: 10 단계, 이미지 3/3
    • Pull each end of the black ribbon cable piece towards the mouse track pad to unlock the ribbon connector piece.
    • Gently pull out the ribbon cable from the connector piece.
  11. ASUS X44H-BBR4 Front Panel Replacement: 11 단계, 이미지 1/1
    • Remove the keyboard completely.
  12. ASUS X44H-BBR4 Front Panel Replacement, Hard Drive: 12 단계, 이미지 1/2 ASUS X44H-BBR4 Front Panel Replacement, Hard Drive: 12 단계, 이미지 2/2
    • Remove the two 9 mm Phillips head screws with the PH0 bit indicated by the red circles in the picture.
  13. ASUS X44H-BBR4 Front Panel Replacement: 13 단계, 이미지 1/2 ASUS X44H-BBR4 Front Panel Replacement: 13 단계, 이미지 2/2
    • Once the screws are removed, slide the back panel away from the computer.
  14. ASUS X44H-BBR4 Front Panel Replacement: 14 단계, 이미지 1/1
    • Remove the 9mm Phillips head screw in the left bottom corner of the hard drive with the PH0 bit.
  15. ASUS X44H-BBR4 Front Panel Replacement: 15 단계, 이미지 1/2 ASUS X44H-BBR4 Front Panel Replacement: 15 단계, 이미지 2/2
    • Slide the hard drive to the left, unlocking it from its default position.
  16. ASUS X44H-BBR4 Front Panel Replacement: 16 단계, 이미지 1/2 ASUS X44H-BBR4 Front Panel Replacement: 16 단계, 이미지 2/2
    • Pull the hard drive upwards and take it out of its position.
  17. ASUS X44H-BBR4 Front Panel Replacement: 17 단계, 이미지 1/3 ASUS X44H-BBR4 Front Panel Replacement: 17 단계, 이미지 2/3 ASUS X44H-BBR4 Front Panel Replacement: 17 단계, 이미지 3/3
    • Remove two 3mm Phillips head screws, one located on each side of the metal casing holding the hard drive using the PH0 bit.
  18. ASUS X44H-BBR4 Front Panel Replacement: 18 단계, 이미지 1/1
    • Pull upwards on the metal casing and it will come off.
  19. ASUS X44H-BBR4 Front Panel Replacement, Front Panel: 19 단계, 이미지 1/3 ASUS X44H-BBR4 Front Panel Replacement, Front Panel: 19 단계, 이미지 2/3 ASUS X44H-BBR4 Front Panel Replacement, Front Panel: 19 단계, 이미지 3/3
    • Lift up the black lock holding the ribbon.
    • Using the blue tab, pull out the ribbon.
    • Pull gently on the ribbon to remove the risk of damaging the ribbon.
  20. ASUS X44H-BBR4 Front Panel Replacement: 20 단계, 이미지 1/1
  21. ASUS X44H-BBR4 Front Panel Replacement: 21 단계, 이미지 1/2 ASUS X44H-BBR4 Front Panel Replacement: 21 단계, 이미지 2/2
    • Remove the five 9 mm Phillips head screws with the PH0 bit.
  22. ASUS X44H-BBR4 Front Panel Replacement: 22 단계, 이미지 1/2 ASUS X44H-BBR4 Front Panel Replacement: 22 단계, 이미지 2/2
    • Flip the laptop on its side so that the red line indicated in the pictures is facing upwards.
  23. ASUS X44H-BBR4 Front Panel Replacement: 23 단계, 이미지 1/2 ASUS X44H-BBR4 Front Panel Replacement: 23 단계, 이미지 2/2
    • Pull up on the disk drive and remove.
  24. ASUS X44H-BBR4 Front Panel Replacement: 24 단계, 이미지 1/2 ASUS X44H-BBR4 Front Panel Replacement: 24 단계, 이미지 2/2
    • Close the laptop and flip it over.
    • Remove the six 12.5 mm screws Phillips head and the five 9 mm screws remaining with the PH0 bit.
  25. ASUS X44H-BBR4 Front Panel Replacement: 25 단계, 이미지 1/3 ASUS X44H-BBR4 Front Panel Replacement: 25 단계, 이미지 2/3 ASUS X44H-BBR4 Front Panel Replacement: 25 단계, 이미지 3/3
    • Flip the device back over and open the laptop.
    • Using the nylon or metal spudger, gently pry off the panel by moving the spudger along the seam.
    • You should hear clicking sounds as the front panel is being removed from the base.
  26. ASUS X44H-BBR4 Front Panel Replacement: 26 단계, 이미지 1/1
    • Remove the panel.
    • The laptop will now become heavier to the front so it will tend to fall on the back side of the screen.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Devaj Ramsamooj
회원 가입일: 10/21/15
824 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 4-3, Catania Fall 2015 UMass Dartmouth, Team 4-3, Catania Fall 2015 회원
UMASSD-CATANIA-F15S4G3
4 회원들
안내서 8개 작성하였습니다
댓글 한 개
Great job! Always stayed away from tablets because of all the hassle. Your guide made it a breeze. Thank You, Thank You
anthois - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 16
전체 시간: 516
