주요 콘텐츠로 건너뛰기
ASUS X44H-BBR4 Hard Drive Replacement
필요한 것
  1. ASUS X44H-BBR4 Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 ASUS X44H-BBR4 Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the device over.
  2. ASUS X44H-BBR4 Hard Drive Replacement: 2 단계, 이미지 1/3 ASUS X44H-BBR4 Hard Drive Replacement: 2 단계, 이미지 2/3 ASUS X44H-BBR4 Hard Drive Replacement: 2 단계, 이미지 3/3
    • Slide the right lock button to the unlock position.
    • After it is unlocked, a red line will be visible.
  3. ASUS X44H-BBR4 Hard Drive Replacement: 3 단계, 이미지 1/2 ASUS X44H-BBR4 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Slide the left lock button into the unlock position and hold.
  4. ASUS X44H-BBR4 Hard Drive Replacement: 4 단계, 이미지 1/3 ASUS X44H-BBR4 Hard Drive Replacement: 4 단계, 이미지 2/3 ASUS X44H-BBR4 Hard Drive Replacement: 4 단계, 이미지 3/3
    • While holding the left lock button in the unlock position, push the battery from the center away from you.
  5. ASUS X44H-BBR4 Hard Drive Replacement, Hard Drive: 5 단계, 이미지 1/2 ASUS X44H-BBR4 Hard Drive Replacement, Hard Drive: 5 단계, 이미지 2/2
    • Remove the two 9 mm Phillips head screws with the PH0 bit indicated by the red circles in the picture.
  6. ASUS X44H-BBR4 Hard Drive Replacement: 6 단계, 이미지 1/2 ASUS X44H-BBR4 Hard Drive Replacement: 6 단계, 이미지 2/2
    • Once the screws are removed, slide the back panel away from the computer.
  7. ASUS X44H-BBR4 Hard Drive Replacement: 7 단계, 이미지 1/1
    • Remove the 9mm Phillips head screw in the left bottom corner of the hard drive with the PH0 bit.
  8. ASUS X44H-BBR4 Hard Drive Replacement: 8 단계, 이미지 1/2 ASUS X44H-BBR4 Hard Drive Replacement: 8 단계, 이미지 2/2
    • Slide the hard drive to the left, unlocking it from its default position.
  9. ASUS X44H-BBR4 Hard Drive Replacement: 9 단계, 이미지 1/2 ASUS X44H-BBR4 Hard Drive Replacement: 9 단계, 이미지 2/2
    • Pull the hard drive upwards and take it out of its position.
  10. ASUS X44H-BBR4 Hard Drive Replacement: 10 단계, 이미지 1/3 ASUS X44H-BBR4 Hard Drive Replacement: 10 단계, 이미지 2/3 ASUS X44H-BBR4 Hard Drive Replacement: 10 단계, 이미지 3/3
    • Remove two 3mm Phillips head screws, one located on each side of the metal casing holding the hard drive using the PH0 bit.
  11. ASUS X44H-BBR4 Hard Drive Replacement: 11 단계, 이미지 1/1
    • Pull upwards on the metal casing and it will come off.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Devaj Ramsamooj
회원 가입일: 10/21/15
824 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 4-3, Catania Fall 2015 UMass Dartmouth, Team 4-3, Catania Fall 2015 회원
UMASSD-CATANIA-F15S4G3
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 9
전체 시간: 1,217
