주요 콘텐츠로 건너뛰기
ASUS X44H-BBR4 MotherBoard Replacement
필요한 것
  1. ASUS X44H-BBR4 MotherBoard Replacement, Battery: 1 단계, 이미지 1/2 ASUS X44H-BBR4 MotherBoard Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the device over.
  2. ASUS X44H-BBR4 MotherBoard Replacement: 2 단계, 이미지 1/3 ASUS X44H-BBR4 MotherBoard Replacement: 2 단계, 이미지 2/3 ASUS X44H-BBR4 MotherBoard Replacement: 2 단계, 이미지 3/3
    • Slide the right lock button to the unlock position.
    • After it is unlocked, a red line will be visible.
  3. ASUS X44H-BBR4 MotherBoard Replacement: 3 단계, 이미지 1/2 ASUS X44H-BBR4 MotherBoard Replacement: 3 단계, 이미지 2/2
    • Slide the left lock button into the unlock position and hold.
  4. ASUS X44H-BBR4 MotherBoard Replacement: 4 단계, 이미지 1/3 ASUS X44H-BBR4 MotherBoard Replacement: 4 단계, 이미지 2/3 ASUS X44H-BBR4 MotherBoard Replacement: 4 단계, 이미지 3/3
    • While holding the left lock button in the unlock position, push the battery from the center away from you.
  5. ASUS X44H-BBR4 MotherBoard Replacement, Keyboard: 5 단계, 이미지 1/2 ASUS X44H-BBR4 MotherBoard Replacement, Keyboard: 5 단계, 이미지 2/2
    • Open the laptop to show the keyboard.
  6. ASUS X44H-BBR4 MotherBoard Replacement: 6 단계, 이미지 1/1
    • Look at the top row of the keyboard, you will see a space that has four latches holding the keyboard down.
    • The latches are located above the Esc key, the F5 key, between the F10 and F11 key and the Delete key.
  7. ASUS X44H-BBR4 MotherBoard Replacement: 7 단계, 이미지 1/3 ASUS X44H-BBR4 MotherBoard Replacement: 7 단계, 이미지 2/3 ASUS X44H-BBR4 MotherBoard Replacement: 7 단계, 이미지 3/3
    • Don't pull too hard on the keys otherwise they may fall off.
    • Push the latch away from the keyboard using the spudger point.
    • While pushing the latches use a plastic opening tool and pull up on a key near it.
    • Continue along the rest of the keyboard until it is released at all four latches.
  8. ASUS X44H-BBR4 MotherBoard Replacement: 8 단계, 이미지 1/2 ASUS X44H-BBR4 MotherBoard Replacement: 8 단계, 이미지 2/2
    • Push the keyboard away from the mouse track pad to unlock the bottom from the base.
    • Do not pull too hard because there is a ribbon connecting to keyboard to the motherboard.
  9. ASUS X44H-BBR4 MotherBoard Replacement: 9 단계, 이미지 1/2 ASUS X44H-BBR4 MotherBoard Replacement: 9 단계, 이미지 2/2
    • Flip the keyboard over to reveal the back of it and what is underneath.
  10. ASUS X44H-BBR4 MotherBoard Replacement: 10 단계, 이미지 1/3 ASUS X44H-BBR4 MotherBoard Replacement: 10 단계, 이미지 2/3 ASUS X44H-BBR4 MotherBoard Replacement: 10 단계, 이미지 3/3
    • Pull each end of the black ribbon cable piece towards the mouse track pad to unlock the ribbon connector piece.
    • Gently pull out the ribbon cable from the connector piece.
  11. ASUS X44H-BBR4 MotherBoard Replacement: 11 단계, 이미지 1/1
    • Remove the keyboard completely.
  12. ASUS X44H-BBR4 MotherBoard Replacement, Hard Drive: 12 단계, 이미지 1/2 ASUS X44H-BBR4 MotherBoard Replacement, Hard Drive: 12 단계, 이미지 2/2
    • Remove the two 9 mm Phillips head screws with the PH0 bit indicated by the red circles in the picture.
  13. ASUS X44H-BBR4 MotherBoard Replacement: 13 단계, 이미지 1/2 ASUS X44H-BBR4 MotherBoard Replacement: 13 단계, 이미지 2/2
    • Once the screws are removed, slide the back panel away from the computer.
  14. ASUS X44H-BBR4 MotherBoard Replacement: 14 단계, 이미지 1/1
    • Remove the 9mm Phillips head screw in the left bottom corner of the hard drive with the PH0 bit.
  15. ASUS X44H-BBR4 MotherBoard Replacement: 15 단계, 이미지 1/2 ASUS X44H-BBR4 MotherBoard Replacement: 15 단계, 이미지 2/2
    • Slide the hard drive to the left, unlocking it from its default position.
  16. ASUS X44H-BBR4 MotherBoard Replacement: 16 단계, 이미지 1/2 ASUS X44H-BBR4 MotherBoard Replacement: 16 단계, 이미지 2/2
    • Pull the hard drive upwards and take it out of its position.
  17. ASUS X44H-BBR4 MotherBoard Replacement: 17 단계, 이미지 1/3 ASUS X44H-BBR4 MotherBoard Replacement: 17 단계, 이미지 2/3 ASUS X44H-BBR4 MotherBoard Replacement: 17 단계, 이미지 3/3
    • Remove two 3mm Phillips head screws, one located on each side of the metal casing holding the hard drive using the PH0 bit.
  18. ASUS X44H-BBR4 MotherBoard Replacement: 18 단계, 이미지 1/1
    • Pull upwards on the metal casing and it will come off.
  19. ASUS X44H-BBR4 MotherBoard Replacement, Front Panel: 19 단계, 이미지 1/3 ASUS X44H-BBR4 MotherBoard Replacement, Front Panel: 19 단계, 이미지 2/3 ASUS X44H-BBR4 MotherBoard Replacement, Front Panel: 19 단계, 이미지 3/3
    • Lift up the black lock holding the ribbon.
    • Using the blue tab, pull out the ribbon.
    • Pull gently on the ribbon to remove the risk of damaging the ribbon.
  20. ASUS X44H-BBR4 MotherBoard Replacement: 20 단계, 이미지 1/1
  21. ASUS X44H-BBR4 MotherBoard Replacement: 21 단계, 이미지 1/2 ASUS X44H-BBR4 MotherBoard Replacement: 21 단계, 이미지 2/2
    • Remove the five 9 mm Phillips head screws with the PH0 bit.
  22. ASUS X44H-BBR4 MotherBoard Replacement: 22 단계, 이미지 1/2 ASUS X44H-BBR4 MotherBoard Replacement: 22 단계, 이미지 2/2
    • Flip the laptop on its side so that the red line indicated in the pictures is facing upwards.
  23. ASUS X44H-BBR4 MotherBoard Replacement: 23 단계, 이미지 1/2 ASUS X44H-BBR4 MotherBoard Replacement: 23 단계, 이미지 2/2
    • Pull up on the disk drive and remove.
  24. ASUS X44H-BBR4 MotherBoard Replacement: 24 단계, 이미지 1/2 ASUS X44H-BBR4 MotherBoard Replacement: 24 단계, 이미지 2/2
    • Close the laptop and flip it over.
    • Remove the six 12.5 mm screws Phillips head and the five 9 mm screws remaining with the PH0 bit.
  25. ASUS X44H-BBR4 MotherBoard Replacement: 25 단계, 이미지 1/3 ASUS X44H-BBR4 MotherBoard Replacement: 25 단계, 이미지 2/3 ASUS X44H-BBR4 MotherBoard Replacement: 25 단계, 이미지 3/3
    • Flip the device back over and open the laptop.
    • Using the nylon or metal spudger, gently pry off the panel by moving the spudger along the seam.
    • You should hear clicking sounds as the front panel is being removed from the base.
  26. ASUS X44H-BBR4 MotherBoard Replacement: 26 단계, 이미지 1/1
    • Remove the panel.
    • The laptop will now become heavier to the front so it will tend to fall on the back side of the screen.
  27. ASUS X44H-BBR4 MotherBoard Replacement, MotherBoard: 27 단계, 이미지 1/2 ASUS X44H-BBR4 MotherBoard Replacement, MotherBoard: 27 단계, 이미지 2/2
    • Remove the 5mm Phillips head screw using the PH0 bit.
  28. ASUS X44H-BBR4 MotherBoard Replacement: 28 단계, 이미지 1/3 ASUS X44H-BBR4 MotherBoard Replacement: 28 단계, 이미지 2/3 ASUS X44H-BBR4 MotherBoard Replacement: 28 단계, 이미지 3/3
    • Pull up on the tape holding the tan cable in place.
    • While holding the tape push up on each side of the cable connector to disconnect it.
  29. ASUS X44H-BBR4 MotherBoard Replacement: 29 단계, 이미지 1/1
    • Gently pull out the cable connector.
  30. ASUS X44H-BBR4 MotherBoard Replacement: 30 단계, 이미지 1/3 ASUS X44H-BBR4 MotherBoard Replacement: 30 단계, 이미지 2/3 ASUS X44H-BBR4 MotherBoard Replacement: 30 단계, 이미지 3/3
    • Gently pull out the USB connector attached to the motherboard.
  31. ASUS X44H-BBR4 MotherBoard Replacement: 31 단계, 이미지 1/2 ASUS X44H-BBR4 MotherBoard Replacement: 31 단계, 이미지 2/2
    • Remove the red and white wire connector next to the fan.
  32. ASUS X44H-BBR4 MotherBoard Replacement: 32 단계, 이미지 1/1
    • Take out the motherboard
    • There are still two wires connected to the bottom of the motherboard so remove carefully.
  33. ASUS X44H-BBR4 MotherBoard Replacement: 33 단계, 이미지 1/1
    • Flip the motherboard over next to the laptop base.
  34. ASUS X44H-BBR4 MotherBoard Replacement: 34 단계, 이미지 1/3 ASUS X44H-BBR4 MotherBoard Replacement: 34 단계, 이미지 2/3 ASUS X44H-BBR4 MotherBoard Replacement: 34 단계, 이미지 3/3
    • Remove the white and black wire.
    • The motherboard is not completely separated from the base of the computer.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Devaj Ramsamooj
회원 가입일: 10/21/15
824 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 4-3, Catania Fall 2015 UMass Dartmouth, Team 4-3, Catania Fall 2015 회원
UMASSD-CATANIA-F15S4G3
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 15
전체 시간: 2,015
