소개
Use this guide to help you replace the motherboard or to get to other parts in the laptop. Don't forget to keep track of all your screws.
필요한 것
Remove the two 9 mm Phillips head screws with the PH0 bit indicated by the red circles in the picture.
Lift up the black lock holding the ribbon.
Using the blue tab, pull out the ribbon.
거의 끝나갑니다!
결론
다른 3명이 해당 안내서를 완성하였습니다.
