주요 콘텐츠로 건너뛰기
ASUS X502CA Fan Replacement
필요한 것
  1. ASUS X502CA Fan Replacement, Fan: 1 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove:
    • Eight 9 mm screws.
    • Four 5 mm screws.
  2. ASUS X502CA Fan Replacement: 2 단계, 이미지 1/1
    • Remove the keyboard cover panel by using a plastic opening tool to carefully pop off the clips around the perimeter.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. ASUS X502CA Fan Replacement: 3 단계, 이미지 1/1
    • The keyboard cover panel is connected to the motherboard with ribbons; be careful not to damage them.
    • Lift the keyboard cover carefully.
    • Disconnect the keyboard and touch-pad ribbons using tweezers.
  4. ASUS X502CA Fan Replacement: 4 단계, 이미지 1/1
    • Remove the keyboard cover panel.
  5. ASUS X502CA Fan Replacement: 5 단계, 이미지 1/1
    • Fold up the black plastic arms securing the cables and disconnect them using tweezers or finger nails.
    • If these are not unplugged, the motherboard may shock you.
  6. ASUS X502CA Fan Replacement: 6 단계, 이미지 1/1
    • Disconnect the remaining connectors using tweezers or your finger nails.
  7. ASUS X502CA Fan Replacement: 7 단계, 이미지 1/1
    • Remove the six 5 mm screws using the Phillips #00 screwdriver.
  8. ASUS X502CA Fan Replacement: 8 단계, 이미지 1/1
    • Flip the motherboard over and away from the screen.
  9. ASUS X502CA Fan Replacement: 9 단계, 이미지 1/1
    • Remove the two 5 mm screws with a Phillips #00 screwdriver.
  10. ASUS X502CA Fan Replacement: 10 단계, 이미지 1/1
    • Unplug the fan's power connector using tweezers or your fingernails.
  11. ASUS X502CA Fan Replacement: 11 단계, 이미지 1/1
    • Peel off the marked strip using your fingers.
  12. ASUS X502CA Fan Replacement: 12 단계, 이미지 1/1
    • Lift the fan up and away from the motherboard.
결론
다른 6명이 해당 안내서를 완성하였습니다.
David Conner
회원 가입일: 03/03/15
292 평판
안내서 2개 작성하였습니다
Clemson, Team 14-1, Shirley Winter 2015 Clemson, Team 14-1, Shirley Winter 2015 회원
CLEM-SHIRLEY-W15S14G1
5 회원들
안내서 5개 작성하였습니다
댓글 2개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 7
전체 시간: 7,840
